alberto49 Posted November 18, 2014 Share Posted November 18, 2014 This is my first ever kit from Revell. My daughter brought it to me as a present for my birthday, last February, I was very pleased I started working on it sometimes before holidays, so here following some pictures of what has been done so far: Cockpit details: Incorrect use of light made everything looking very greyish, the real colour I used for the cockpit can be seen in the first picture. Some more to follow very soon. Bill Cross, mywifehatesmodels and SinuheH 3 Link to comment Share on other sites More sharing options...
alberto49 Posted November 18, 2014 Author Share Posted November 18, 2014 Some pictures of the radial engine during completion: Started putting parts together: and first coat of paint: More to follow. Cheers Alberto SinuheH, mywifehatesmodels and Bill Cross 3 Link to comment Share on other sites More sharing options...
SinuheH Posted November 18, 2014 Share Posted November 18, 2014 Nice work ….. keep it up. Link to comment Share on other sites More sharing options...
alberto49 Posted November 18, 2014 Author Share Posted November 18, 2014 My goal is to try to replicate this machine: better seen in this profile therefore I started with a coat of RLM72 but, before going on with the next colour, I wanted to see if I could arrange a suitable arrangement for my model: it's a float plane, so she should be floating in water. I purcased a doc set from Italeri and I assembled it: Doesn't look too bad and I intended to fill it with clear resin to simulate water. But there is a problem, unfortunately, it's too small, the aeroplane will not look right in it. It has been a good exercise for me, but I have already put it aside just in case I have the opportunity to use it for something else. So I will have to chose: either I will do a larger one, but then I will have problems in fitting it in my cabinet, or I will do it differently, will see. Alberto mywifehatesmodels 1 Link to comment Share on other sites More sharing options...
LSP_Ron Posted November 19, 2014 Share Posted November 19, 2014 well that's to bad, it looks great. To bad you didn't fold one wing? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 19, 2014 Share Posted November 19, 2014 Nice progress Alberto. It's a shame about the dock not being usable, but perhaps you can base a scratch-built one off it? Kev Link to comment Share on other sites More sharing options...
alberto49 Posted November 19, 2014 Author Share Posted November 19, 2014 Many thanks for your comments Ron and Kev. I facts I really made wrong assumptions when I was I was designing that doc. I will try to post soon a picture that will explain what I mean. Alberto Link to comment Share on other sites More sharing options...
Bill Cross Posted November 19, 2014 Share Posted November 19, 2014 My solution to displaying this kit was a little more elaborate, but it worked: MikeC 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 19, 2014 Share Posted November 19, 2014 Alberto The dio would have looked great. Either a larger dio or Bill's method will yield great results. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
MikeC Posted November 20, 2014 Share Posted November 20, 2014 (edited) Looking good. I'm doing this one at the moment too, interesting to see your slightly different approach as to when to fit the floats and wings. http://forum.largescaleplanes.com/index.php?showtopic=53170&hl= Have to confess you've done far more work on the engine (in particular) than I have, it looks great. Edited November 21, 2014 by MikeC Link to comment Share on other sites More sharing options...
dennismcc Posted November 20, 2014 Share Posted November 20, 2014 Looking good, shame about the dock though. Cheers Dennis Link to comment Share on other sites More sharing options...
alberto49 Posted November 20, 2014 Author Share Posted November 20, 2014 Again thanks to all for the comments. In answer to Bill, the catapult is a very good idea, even if not in line with my intent to make a Mediterranean bird that looks a bit more colourful. But I could change my mind if I don't find a different solution to achieve my goal. To MikeC, I decided to leave the float unassembled at least until they will painted with the second camouflage color. Alberto Link to comment Share on other sites More sharing options...
alberto49 Posted November 22, 2014 Author Share Posted November 22, 2014 I did a mock-up arrangement and, as you will see below, if the seaplane model is positioned with the tail pointing to the dock, it looks really bad, I think. The piece of balsa wood is intended to define the depth of water under floats. Afterwords some more resin will be purred in order to reach the floating level. Instead, if it the nose to point the dock, it is a bit better, in my opinion, but I still think that's not realistic to show a wing that protrudes beyond dock's walls. I will see after the camou painting will be complete. Alberto Bill Cross 1 Link to comment Share on other sites More sharing options...
alberto49 Posted November 22, 2014 Author Share Posted November 22, 2014 One more picture Link to comment Share on other sites More sharing options...
alberto49 Posted November 23, 2014 Author Share Posted November 23, 2014 I have one question for Bill as well as all other guys following my thread: in your opinion the transition between camouflage colours (RLM 70 & RLM 72) is it neat or soft? According to a document I found, referred to BF 109, the colours should overlap 10 cm in 1:1 scale, so aprox 3 mm in my scale, what do you think? Many thanks Alberto Link to comment Share on other sites More sharing options...
