Hawkwrench Posted April 29, 2015 Share Posted April 29, 2015 Hello all, I will be starting a 1/35th scale MH-60M Blackhawk helicopter from the 160th SOAR soon and I will be covering it with rivets. What's the proper way to use these decals?- Apply straight to the model with no prep? Or gloss coat first, then decal? I need some help PLEASE!!! Tim Link to comment Share on other sites More sharing options...
LSP_Paul Posted April 29, 2015 Share Posted April 29, 2015 Tim, Draw the rivet lines on the cleaned and filled partially assembled model in pencil, double check then triple check the lines for accuracy Then, seal the pencil lines on the bare plastic under gloss coat, this helps them not get rubbed off handling the model. Once your gloss coat is dry, apply the decals on the glossy surface using your triple checked lines as a guide. Then once the decals are set, you can seal them again under gloss coat ( or not) and paint and weather as normal. Be aware that like any other decals, once applied they may be susceptible to being pulled up with any masking,( that's why I gloss coat over them before paint ) so if you have to mask anything, use de- tacked low tack tape or wet typing paper as a mask over rivet lines. Have fun and I'm looking forward to your progress and Paul Harold 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted April 29, 2015 Share Posted April 29, 2015 I concur. Use as much softener and setter as possible on the decals, on a gloss prepped surface, and cover them again (gloss coat or paint) before applying any masking. See my current thread on the Fisher St-M. I just had the mishap yesterday about masking tape pulling some Archer rivets, in spite of the paint overcoat ... http://forum.largescaleplanes.com/index.php?showtopic=54706&page=2 Hubert Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 2, 2015 Share Posted May 2, 2015 What is the difference between Archer and Micromark rivets? Peter Link to comment Share on other sites More sharing options...
Hawkwrench Posted May 3, 2015 Author Share Posted May 3, 2015 Micromark's sheets are ALOT bigger, which means more rivets. Plus, you get 2 sheets of them! Tim Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 3, 2015 Share Posted May 3, 2015 Tim Are both decals the same quality and applied the same way? Thank you Peter Link to comment Share on other sites More sharing options...
Hawkwrench Posted May 3, 2015 Author Share Posted May 3, 2015 I have never used Archer decals, but I imagine their quality is top notch. And yes they are applied the same way just like regular decals. Their realism when applied to a model piece is incredible. I highly recommend them if you want a realistic looking model! Tim Link to comment Share on other sites More sharing options...
Monty Python Posted May 3, 2015 Share Posted May 3, 2015 This might seem a silly question but having never seen the rivet decals, I take it they sit slightly raised of the models surface but by how much? Link to comment Share on other sites More sharing options...
Hawkwrench Posted May 3, 2015 Author Share Posted May 3, 2015 They stick out some, but not very much (that's vague, I know). Can't really measure them but trust me, they look real after primer is applied. Tim Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 3, 2015 Share Posted May 3, 2015 Here are some Archer rivets applied over the Fisher STM fuselage, where I had sanded them off during seam elimination:Note that these rivets are the ones Paul recommends to use for this purpose on his kit, and are in fact the ones he used to form the rivets in the first place. So you can see what they look like under primer on the rest of the model.Of course, there are finer rivets than these available, from Archer as well as Micromark and HGW.Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 3, 2015 Share Posted May 3, 2015 Thanks Kev For 32nd scasle is there a size or a sheet number we should be looking at? Peter Link to comment Share on other sites More sharing options...
wunwinglow Posted May 29, 2015 Share Posted May 29, 2015 Archer also do a lot of other texture decals, from wood grain, tread plate patters, weld seams , casting codes and manufacturers mars, and more. the Archer sets Are physically much bigger sheets , and two per pack, but include just a variety of rivet heads in various pitches and patterns. I have used both and they work equally well, as described above. Tim Link to comment Share on other sites More sharing options...
