wingman777 Posted October 2, 2008 Author Share Posted October 2, 2008 Just one more to settle the gun issue Link to comment Share on other sites More sharing options...
bdthoresen Posted October 3, 2008 Share Posted October 3, 2008 Bout time you put up some pics you old pirate!!! I like the work so far- Keep it up!!!!! THOR Link to comment Share on other sites More sharing options...
big matt Posted October 3, 2008 Share Posted October 3, 2008 Cool idea with the tubing and the comparison picture for the rivet and panel line detail. Looking forward to seeing more progress on this one. Matt Link to comment Share on other sites More sharing options...
wingman777 Posted October 3, 2008 Author Share Posted October 3, 2008 The more time I spend on this kit the more I appreciate it. Check the kit engine hub and cylinders against the real deal. Link to comment Share on other sites More sharing options...
wingman777 Posted October 3, 2008 Author Share Posted October 3, 2008 even the cockpit parts look susprisingly accurate but I'll use the Eduard PE set to make it even better. The kit, PE set and aftermarket decals still cost half what the Trumpeter kit cost. Link to comment Share on other sites More sharing options...
wingman777 Posted October 12, 2008 Author Share Posted October 12, 2008 Rather than sand and scribe the surface detail I'm going to use the kit detail and tone it down a bit. I've applied several coats of Krylon "Fusion" glossy white spray paint straight from the can. Fusion is "specially formulated to adhere to plastic" and goes on uniformly, dries really smooth. The paint is thin so there isn't a build-up even with 4 coats. so far I've painted the wings and horizontal stabilizers. Link to comment Share on other sites More sharing options...
wingman777 Posted October 12, 2008 Author Share Posted October 12, 2008 OOOOOPS, sorry wrong image...these are the superchargers I made using the PE pattern that Eduard gives. The PE kit only gives one and there should be two so whatever.... Link to comment Share on other sites More sharing options...
wingman777 Posted October 12, 2008 Author Share Posted October 12, 2008 Here are the images of the painted surfaces as described earlier.... (sheesh) Link to comment Share on other sites More sharing options...
wingman777 Posted October 12, 2008 Author Share Posted October 12, 2008 Still making progress with the cockpit, engine and landing gear compartments. Link to comment Share on other sites More sharing options...
check 6 Posted October 13, 2008 Share Posted October 13, 2008 Nice work you're really making some great progress,I'll be watching this build for sure , be looking forward to the next update Ed Link to comment Share on other sites More sharing options...
wingman777 Posted January 5, 2009 Author Share Posted January 5, 2009 Hey guys, after a long dry spell I finally made some more progress on the Wildcat. The cockpit has been improved with the Eduard set and some scratch building. The engine is wired with lead solder and connected to the fuselage. Link to comment Share on other sites More sharing options...
wingman777 Posted January 5, 2009 Author Share Posted January 5, 2009 Oooops sorry the images didn't load...I'll try again Link to comment Share on other sites More sharing options...
wingman777 Posted January 5, 2009 Author Share Posted January 5, 2009 maybe it'll work this time Link to comment Share on other sites More sharing options...
wingman777 Posted February 24, 2009 Author Share Posted February 24, 2009 Guys, sorry about the images not showing up from last time. Since then my wife's digital camera had to be sent back to Canon for repairs. We have it back now and the Wildcat is near completion. Its assembled and painted, I was going to use the decals but they're ancient and probably won't work well. The project has turned out nicely to this point so I was going to order the Montex masks to paint the insignia on but they are out of stock. Its obvious I won't make the deadline for this group build but might be able to get it under the wire for the "incomplete group build" that finishes up next month. I'll try to get some fresh images to post either way. Link to comment Share on other sites More sharing options...
wingman777 Posted March 3, 2009 Author Share Posted March 3, 2009 I'm on the home stretch and with a few days might be able to complete it in time for this group...I'll try to post some images soon. (whew) hurry, hurry Link to comment Share on other sites More sharing options...
