wunwinglow Posted April 29, 2015 Author Share Posted April 29, 2015 Iain, is your mailbox full? Tim Link to comment Share on other sites More sharing options...
Iain Posted April 29, 2015 Share Posted April 29, 2015 Ooops - er yes - and, er not now - try again Haven't replied to your resin message yet - mind's been elsewhere - will ping you tomorrow... Iain Link to comment Share on other sites More sharing options...
wunwinglow Posted May 1, 2015 Author Share Posted May 1, 2015 Filled a few gaps with acryl red filler, wet sanded with 600 grit paper to get the bulk of the surplu off. Then sawed through the filler blocks to separate the fuselage halves. Now they look like this..... Out2gtcha and Girlscanplay2 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 1, 2015 Share Posted May 1, 2015 Nice! For whatever reason, I really like looking at models that are in a "raw" form with soothed out filler all over them..............I guess I know how much work goes into filling and sanding. Girlscanplay2 1 Link to comment Share on other sites More sharing options...
seiran01 Posted May 1, 2015 Share Posted May 1, 2015 This is looking very strange, and very cool! Link to comment Share on other sites More sharing options...
wunwinglow Posted May 5, 2015 Author Share Posted May 5, 2015 I opened up the wheel wells forwards to make room for the bigger Sea Fury wheels and tyres I am robbing from the Hobbycraft Sea Fury, as these will be replaced with the fantastic Fisher parts. I also started filling in the wing roots, as there is a gap where the stretch went.. I still haven't decided how i am going to alter the wings, but with two sets of kit parts to play with I have a few options. Out2gtcha 1 Link to comment Share on other sites More sharing options...
BGB Posted May 5, 2015 Share Posted May 5, 2015 Hello,, This will be interesting Nice work going on there. Cheers Boris Link to comment Share on other sites More sharing options...
wunwinglow Posted June 20, 2015 Author Share Posted June 20, 2015 Started work again as I finally managed to clear some proper space in my Man Shed. Iain, Out2gtcha and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
wunwinglow Posted June 23, 2015 Author Share Posted June 23, 2015 (edited) Insert drawn up and 3D printed, glued the inner wings together and smothered the join with a bit of filler... Edited June 23, 2015 by wunwinglow Link to comment Share on other sites More sharing options...
wunwinglow Posted June 27, 2015 Author Share Posted June 27, 2015 (edited) Inner wing panels sanded top surfaces, and another trial assembly. I'll box in the undercarriage bays next, then look at the outer panels as they will need lengthening to match the longer inner panels.Tim Edited June 27, 2015 by wunwinglow Link to comment Share on other sites More sharing options...
wunwinglow Posted June 30, 2015 Author Share Posted June 30, 2015 Made up the outer wing panels, which will be folded. I used the existing outer panels, and cut up the remaining spare inner wings from the second kit, at a point where the chord matched to new extended wings. It took a fair bit of fiddling to get it to all line up. Lots of braces across the joins, then i will sand it all smooth when the glue has set hard. Tim Girlscanplay2 and Out2gtcha 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted June 30, 2015 Share Posted June 30, 2015 Looks great Tim. Reminds me of a Sea Fury in some of your pics. Carl Link to comment Share on other sites More sharing options...
dodgem37 Posted June 30, 2015 Share Posted June 30, 2015 What a great project! I had no idea there was so much of a difference between the U.S. Navy and French Bearcat. Or is the kit so far off this is what's needed to make a production Bearcat? Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
wunwinglow Posted June 30, 2015 Author Share Posted June 30, 2015 Mark, this isn't a real aircraft! I am just hacking a 'What-If?' from two Bearcat kits I had hanging around. I always thought the Bearcat looked a bit stumpy, so thought I'd do a bit of customising. I have no ide what it will look like in the end, probably a cross between a bubble top Corsair, Wildcat, and maybe Firebrand, especially if I finish it in Fleet Air Arm colours, which is the aim. Actually, I'm having a ball with this one, no hang-ups over accuracy! Just going with it..... Tim Out2gtcha 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted June 30, 2015 Share Posted June 30, 2015 Silly me! I was so absorbed with what you are doing I lost sight of the intent. Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
