otis252 Posted July 24, 2017 Share Posted July 24, 2017 Hey guys, there was a build thread that had a link to another build in it I saw a few days ago. I went back to bookmark it yesterday and I can't find it. Anyone have a link to it? Many thanks. Chuck F`s are my favs 1 Link to comment Share on other sites More sharing options...
88phantom Posted July 24, 2017 Share Posted July 24, 2017 Check under the Group Build, 70 Years USAF.....there are 2 over there! West Link to comment Share on other sites More sharing options...
otis252 Posted July 24, 2017 Author Share Posted July 24, 2017 I found the link I was looking for. I'd suggest anyone building this kit take a look at this build. https://designer.home.xs4all.nl/models/f35-32/f35-32-1.htm Link to comment Share on other sites More sharing options...
timvkampen Posted July 25, 2017 Share Posted July 25, 2017 the RAM panels look / are too thick. Same issue with the MENG kit I believe. Maybe an extra spray of primer can solve it? Link to comment Share on other sites More sharing options...
phantomdriver Posted July 25, 2017 Share Posted July 25, 2017 The MENG kit is far worse... Link to comment Share on other sites More sharing options...
Dave Williams Posted July 25, 2017 Share Posted July 25, 2017 the RAM panels look / are too thick. Same issue with the MENG kit I believe. Maybe an extra spray of primer can solve it? If you're thinking of raising the surrounding surface, you'd have to mask off all of the raised RAM panels, and use a deliberately thick primer. Link to comment Share on other sites More sharing options...
themongoose Posted July 25, 2017 Share Posted July 25, 2017 Gray automotive high build primer would bring it up. Con - I think the problem would be losing the surrounding detail. Pros, may outweigh the con - If you painted the whole plane in the color for the RAM panels, then masked everything it wouldn't cost any more effort than normal. That would also put anothe rlayer on to build it up. Interesting concept that would save the uneven look that seems to hapen after sanding. Link to comment Share on other sites More sharing options...
