Martinnfb Posted June 11, 2016 Share Posted June 11, 2016 (edited) Edited June 11, 2016 by Martinnfb Link to comment Share on other sites More sharing options...
Martinnfb Posted June 11, 2016 Share Posted June 11, 2016 Link to comment Share on other sites More sharing options...
LSP_Paul Posted June 11, 2016 Author Share Posted June 11, 2016 Thank you Martin! This is the side I need to see under. If you look next to the intakes, you can see there is a structure under the gills/vents on the canopy frame rear. Paul Martinnfb 1 Link to comment Share on other sites More sharing options...
LSP_Paul Posted June 11, 2016 Author Share Posted June 11, 2016 Perfect I can work from that! Thank you Martinnfb and Uncarina 2 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 11, 2016 Share Posted June 11, 2016 and , the kinky part Link to comment Share on other sites More sharing options...
otis252 Posted June 11, 2016 Share Posted June 11, 2016 Gosh I hope this is the build where somebody fixes the "kinky part" on that terrible leading edge of the wing. Chuck LSP_Paul and Martinnfb 2 Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2016 Share Posted June 11, 2016 Martin's sure a good friend to have. His ability to dig up cool pictures is second to none. WOW! You know how smart those Ruskie spy's are.....Harv Link to comment Share on other sites More sharing options...
LSP_K2 Posted June 11, 2016 Share Posted June 11, 2016 Great photos indeed. They should help a lot, I'd think. LSP_Paul 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 11, 2016 Share Posted June 11, 2016 I always wanted to build one, actually , not always, I believe since the First Bush War. So I started studying the engineering of this plane and it is nuts, true Science fiction for it's time. The wing itself is absolute aeronautical marvel. No sharp edges, no flat places just a variable flow moving at every angle. And Paul if you want to stand out with this build, do not forget to distress a hell out of it, please...........and thank you Link to comment Share on other sites More sharing options...
LSP_Paul Posted June 11, 2016 Author Share Posted June 11, 2016 Well Martin, a LOT of the UK guys are chomping at the bit for somebody to make a nice accurate nose for the GR7, Grab a Brit Harrier kit and join me, master the nose profile like you did the profiles for the P-39. That was so explanatory and well photographed, and the nose shape is easier to get right on the late British Harrier than the P-39 work you did. Oh look, I found you one cheap! http://www.hobbylinc.com/trumpeter-raf-harrier-gr-mk-7-attack-aircraft-plastic-model-airplane-kit-1:32-scale-2287?source=froogle&gclid=COrii96Jn80CFQJsfgodvBAOjw Skeeter Uncarina 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted June 11, 2016 Share Posted June 11, 2016 Not cheap enough http://www.luckymodel.com/scale.aspx?item_no=TP02229 Link to comment Share on other sites More sharing options...
