SirBlueHenry Posted June 25, 2017 Author Share Posted June 25, 2017 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 25, 2017 Author Share Posted June 25, 2017 I have no idea what this hole is that is seen half covered by this small fairing piece on the port side of the nose. First I thought it was easy access for oil filling filling but i think the oil filler panel is more to the right and a bit higher up. So what is this hole anbd fairing for? Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 25, 2017 Author Share Posted June 25, 2017 Anthony in NZ 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 25, 2017 Author Share Posted June 25, 2017 Opening up the 2 venturis, getting ready for fitting. Still need to try and create a short exhaust tube. I managed to get a great arrangement of the cowling without touching any part of the fuselage. Radio mast fitted. Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted June 25, 2017 Share Posted June 25, 2017 I have no idea what this hole is that is seen half covered by this small fairing piece on the port side of the nose. First I thought it was easy access for oil filling filling but i think the oil filler panel is more to the right and a bit higher up. So what is this hole anbd fairing for? It's the carburetor air intake, IIRC. Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 25, 2017 Author Share Posted June 25, 2017 oooh yes - of course. Thanks. I was totally put off by it being covered against forward airflow as opposed to T6 variants with ram air intake. Next question. The 2 venturis on the stbd side. What were they for? Driving a couple of instruments? Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted June 25, 2017 Share Posted June 25, 2017 oooh yes - of course. Thanks. I was totally put off by it being covered against forward airflow as opposed to T6 variants with ram air intake. Next question. The 2 venturis on the stbd side. What were they for? Driving a couple of instruments? Yes; the gyroscopic instruments have a vacuum drive which the venturi tubes power. I actually thought that the cover opened forward. If it opens aft, it's more likely to be a vent. Perhaps it helps to vent Carbon Monoxide or fuel fumes overboard? We're talking about the one immediately below the antenna, correct? Link to comment Share on other sites More sharing options...
DerekB Posted June 26, 2017 Share Posted June 26, 2017 It's the carburetor air intake, IIRC. Jessie, actually the vent is an outlet for oil cooler air. The oil cooler is mounted inside the cowling just near this vent. The carb air intake is inside the cowl at the 6 o'clock position, with the duct running along the underside of the cowl leading to the carburettor. Cheers, Derek Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 26, 2017 Author Share Posted June 26, 2017 Thanks Derek Link to comment Share on other sites More sharing options...
Guest Jessie_C Posted June 26, 2017 Share Posted June 26, 2017 Jessie, actually the vent is an outlet for oil cooler air. The oil cooler is mounted inside the cowling just near this vent. Thanks, Derek. As soon as I heard that it faced backwards I knew it couldn't be an intake Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 27, 2017 Author Share Posted June 27, 2017 Took a bit of a break from the model table, and spent some time reading model railroad magazines. Slowly starting to get slightly into model railroad but with more focus on the setting and diorama than the rail. One project I want to start soon is a 1/72 Hanger for such a diorama. Link to comment Share on other sites More sharing options...
SirBlueHenry Posted June 29, 2017 Author Share Posted June 29, 2017 Anthony in NZ 1 Link to comment Share on other sites More sharing options...
SirBlueHenry Posted July 15, 2017 Author Share Posted July 15, 2017 I have managed the delicate operation of getting the undercarriage mounts glued in. Also started filling the joint gap at the horizontal stab. photos to follow soon. next jobs are the fixing of the fillet on the horizontal stab, landing light covers and Leading edge pieces Link to comment Share on other sites More sharing options...
Joel_W Posted July 15, 2017 Share Posted July 15, 2017 SBH, Those exhausts really look quite impressive. I do have mixed feelings about trying to mix Model Railroading and Plastic Modeling. I've yet to find anyone that has enough time to devote to both hobbies. Joel Link to comment Share on other sites More sharing options...
