LSP_Kevin Posted July 29, 2014 Share Posted July 29, 2014 Looks great Rick! What is FICE? Kev Link to comment Share on other sites More sharing options...
Rick K Posted July 29, 2014 Author Share Posted July 29, 2014 Looks great Rick! What is FICE? Kev F--k It Close Enough My prime directive. Sparzanza 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted July 29, 2014 Share Posted July 29, 2014 Looks great! I have my eye on that hex punch as my old one (diff manufacturer) has about had it... What are your thoughts on the tool you have?? (Hex punch in pic)?? Thanks Cheers Alan Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2014 Share Posted July 30, 2014 Looks great! I have my eye on that hex punch as my old one (diff manufacturer) has about had it... What are your thoughts on the tool you have?? (Hex punch in pic)?? Thanks Cheers Alan I reviewed that set a little while back: http://www.largescaleplanes.com/reviews/review.php?rid=1249 And the round one: http://www.largescaleplanes.com/reviews/review.php?rid=1248 Kev Rick K 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 30, 2014 Share Posted July 30, 2014 F--k It Close Enough My prime directive. Thanks Rick. I should have guessed! Kev Rick K 1 Link to comment Share on other sites More sharing options...
JJYL Posted August 2, 2014 Share Posted August 2, 2014 Nice progress Rick K 1 Link to comment Share on other sites More sharing options...
Paramedic Posted August 5, 2014 Share Posted August 5, 2014 Nice job there, I especially love that engine! Gonna have this thread a s a reference when I get started on mine.. Nice choice on the individual as well, sweet looking kite. Rick K 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted August 5, 2014 Share Posted August 5, 2014 Rick Some really nice work and excellent progress Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Rick K Posted August 5, 2014 Author Share Posted August 5, 2014 Looks great! I have my eye on that hex punch as my old one (diff manufacturer) has about had it... What are your thoughts on the tool you have?? (Hex punch in pic)?? Thanks Cheers Alan Really happy with his tool. Rather expensive, but it is well constructed. I predict a long life with this. Link to comment Share on other sites More sharing options...
Rick K Posted August 6, 2014 Author Share Posted August 6, 2014 It has been a struggle to find bench time with recent family obligations. That said, I'll provide some additional shots of the finished M10's along with build progress images. My final pan is to add ignition wires and ordnance before mounting to "Slick Chick". Have yet to formulate an ordnance solution. Comparison with 2 Trumpy M10's I detailed with flat lead wire. The Trumpy M10's came out ok. However, I am glad I pulled the plug on the enhancements and go with the scratch build M10's. Styrene tube cut to 2mm slices set as mount stops. End pieces, nuts and washers added Using a hairdryer I slightly heated then bent the channel styrene. Mounts with swing arms attached to the tubes. Styrene rod with ends drilled out for ignition wire conduit added to the tubes. Mounts made from styrene rod and various sizes of styrene strips. Styrene strips added for the securing wraps. 3 styrene tubes glued together is just the beginning. Lars Befring and Bill Cross 2 Link to comment Share on other sites More sharing options...
Rick K Posted September 16, 2014 Author Share Posted September 16, 2014 M10 BULLETS The M10 tubes need to be loaded so back to some creative engineering. Rocket tubes primed with Mr.Color 1500 Black, olive drab will be main color applied. Using a 3.2mm (1/8") styrene tube I cut 6 pieces approx 2cm length. Thin the walls with a round file. A 1.5mm round rod is inserted to create depth at the rocket nozzle. The 1.5mm rod is depressed about 1mm into the tube then liquid cement applied. Will drill a small hole to accommodate the ignition wire. Will trim the rod about 3mm from tube. Plan is to paint some shade of dark aluminum. TBD. Test fit of M10 bullets and ignition wire. Wire will be trimmed and inserted into middle of each rocket. Mal_Belford, Lars Befring and Bill Cross 3 Link to comment Share on other sites More sharing options...
Loic Posted September 16, 2014 Share Posted September 16, 2014 Looks good Link to comment Share on other sites More sharing options...
Mal_Belford Posted September 17, 2014 Share Posted September 17, 2014 Yeah i do agree it looks real good and i mean real good... /Mal Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 17, 2014 Share Posted September 17, 2014 Looking real good Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Rick K Posted September 17, 2014 Author Share Posted September 17, 2014 Looks good Yeah i do agree it looks real good and i mean real good... /Mal Looking real good Keep 'em coming Peter Thanks guys. The work continues...... Link to comment Share on other sites More sharing options...
