mark31 Posted February 15, 2014 Author Share Posted February 15, 2014 another small update. Didt some work on the rivets. On some places the rivets are almost unviseble. So time to take the drill and have a few hours of fun. left side done now the right side. Mark Iain 1 Link to comment Share on other sites More sharing options...
marauderdriver Posted February 15, 2014 Share Posted February 15, 2014 Hi Mark you guys and your rivets...... Look at www.aircraftresourcecenter.com and search Peter Doll.....................This is my inspiration for FOILING tho I have never communicated with him Jack mark31 1 Link to comment Share on other sites More sharing options...
mark31 Posted February 15, 2014 Author Share Posted February 15, 2014 Hi Mark you guys and your rivets...... Look at www.aircraftresourcecenter.com and search Peter Doll.....................This is my inspiration for FOILING tho I have never communicated with him Jack Yes i have seen a fe foild models of him and the look great. And about the rivets i now a bit crazy. Mark Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 15, 2014 Share Posted February 15, 2014 Mark I'm following jacks lead and not going to knock myself out with the rivets, as I'm only planning on replacing the ones I've lost sanding. Peter Link to comment Share on other sites More sharing options...
mark31 Posted February 15, 2014 Author Share Posted February 15, 2014 Mark I'm following jacks lead and not going to knock myself out with the rivets, as I'm only planning on replacing the ones I've lost sanding. Peter Maybe thats the best idee to do there are to many to do. Mark Link to comment Share on other sites More sharing options...
marauderdriver Posted February 15, 2014 Share Posted February 15, 2014 Hey don't let me influence you guys I think the heavy rivets around the tail should be weathered as they are larger and not flush as the skin rivets are I'll shut up now Jack Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 16, 2014 Share Posted February 16, 2014 (edited) Hi Mark Just checking on how you made out with the main gear wells. I'm just about at the same place you are now, having removed the kit wheel wells, spent a lot of time sanding and then more sanding but it's smooth as glass now on the inside. Test fitting shows the outer gear box to be way to thick and will need to be sanded down a lot.. Have you taken a look at the problem yet? I'll be having more fun sanding and filing in the morning. Peter Edited February 16, 2014 by Peterpools Link to comment Share on other sites More sharing options...
mark31 Posted February 16, 2014 Author Share Posted February 16, 2014 Hello Peter. i jus removd the inner parts on the top of the wings and the wings fit. u will need o modifie te front feuselage to fit the wings will try to take a few pics and will place them. Mark Link to comment Share on other sites More sharing options...
mark31 Posted February 16, 2014 Author Share Posted February 16, 2014 wings gleud togheter. When dry fitting the front feuselage to the wings i had this. The wheelbays from aires are against the side of the feuselage. So i have marked on the insideof the feuselage where the are touching. Removed some plastic. And now the fit. Mark Link to comment Share on other sites More sharing options...
SinuheH Posted February 16, 2014 Share Posted February 16, 2014 Nice work, on the Sabre, Mark….. those wheel bays look great, as does the air brake! I plan on starting my Hasegawa Sabre today…… Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 16, 2014 Share Posted February 16, 2014 Mark Thanks for the photos and I have a good idea now where and what to sand before thinning down the Aires part. Thanks Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 16, 2014 Share Posted February 16, 2014 Hi Mark Just went back and removed the landing gear square plug on the upper wing and also one injector pin mark as well. Fit is so much better and with a bit of tweaking, I should be good to go. Will be devoting my modeling time today to finishing up the forward portion of the fuselage and all the sub assemblies. I finally have all the resin parts dry fitted - IP, cowling and nose gear well and with a bit of tweaking, all the parts now fit without any squeezing or pressure. Thanks for the help Peter Link to comment Share on other sites More sharing options...
mark31 Posted February 16, 2014 Author Share Posted February 16, 2014 Its notting Peter glad i could help u. Last update for this week. Its start to look like a sabre to me. Mark Link to comment Share on other sites More sharing options...
Loic Posted February 16, 2014 Share Posted February 16, 2014 Indeed ! Looking good Mark Link to comment Share on other sites More sharing options...
Guest Peterpools Posted February 16, 2014 Share Posted February 16, 2014 Hi Mark Fantastic progress on the Sabre ... I'm slow and seams getting a bit slower compared to your build. Sure hope to be able to post an update later today. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
