Fooesboy Posted July 26, 2015 Share Posted July 26, 2015 Hey guys, As the title suggests I'm having a spot of bother with the chipping fluid, when I spray my top coat over the chipping fluid (Tamiya thinned with X20a) I am getting a crazy cracked surface. Any suggestions? Cheers, Chris Link to comment Share on other sites More sharing options...
Hardcore Posted July 26, 2015 Share Posted July 26, 2015 hm, you did let the fluid dry first? Link to comment Share on other sites More sharing options...
Fooesboy Posted July 26, 2015 Author Share Posted July 26, 2015 Sure did, 3 coats of fluid and left for a couple of hours. Interestingly, the yellow looks great its the green where I am having the most trouble. Going to bed now but will post a photo tomorrow. Link to comment Share on other sites More sharing options...
Fooesboy Posted July 27, 2015 Author Share Posted July 27, 2015 Here is a photo of the seat, it is easy to see the crazy cracking Link to comment Share on other sites More sharing options...
Mal_Belford Posted July 27, 2015 Share Posted July 27, 2015 Ive got that effect ......two reasons. Old AK schipping fluid it is sligtly to thick so to thick layer....two to much paint at the time...better build.layers.... As in my case eded up as a redoo.... So try a new bottle..and two mist layers... Hope it helps... /Mal Fooesboy and Zero77 2 Link to comment Share on other sites More sharing options...
Fooesboy Posted July 27, 2015 Author Share Posted July 27, 2015 Cheers Mal, This is a brand new bottle I picked up while on holiday in Japan.... Can't find it here! I did find it rather thick for spraying and thought the fluid was not coating very well at all, it was quite lumpy but seamed to self level as it dried. Does anyone know if it can be thinned? Chris Link to comment Share on other sites More sharing options...
Mal_Belford Posted July 27, 2015 Share Posted July 27, 2015 There are several AK chipping fluid... One normal and obe Heavy.... Ive foundnthat the heavy is worse and more thick....it rubs thru AB but bad...the normal one is like water and atomizes much better...... As ive discded one bittle of AK normal chipping fluid cause it were to rhick....opened another one and far better. /Mal Fooesboy 1 Link to comment Share on other sites More sharing options...
Fooesboy Posted July 27, 2015 Author Share Posted July 27, 2015 Great, thanks a lot! Looks like I will need to strip and try again. I have the worn effects as well that I will try next, I am thinking on the cockpit floor where the pilots feet would be. Link to comment Share on other sites More sharing options...
Mal_Belford Posted July 27, 2015 Share Posted July 27, 2015 Avoid AK Heavy chipping fluid if youre after a smooth fine surface, it affects paintcoat and doesnt look smooth at all....get more rugged look.... It works great on tanks that got a more rugged surface for the beginning..but aircraft....no . That is my opinion. /Mal Zero77 1 Link to comment Share on other sites More sharing options...
Fooesboy Posted July 27, 2015 Author Share Posted July 27, 2015 I think you are right Mal, I have posted some other photos in my build thread.... http://forum.largescaleplanes.com/index.php?showtopic=55505&page=7and I'm not sure about the look. I guess the good thing about PE and white metal it will be easy to strip and have another go. Link to comment Share on other sites More sharing options...
modelingbob Posted July 27, 2015 Share Posted July 27, 2015 Your picture tells me that you #1) airbrushed on way too much chipping fluid (a single coat will suffice, you want the look to be somewhat "lumpy" and not smooth before drying). and #2) you airbrushed on way too much Tamiya paint which caused the cracking effect as it dried over the too thick layer of chipping fluid. It sometimes takes a bit of practice to get both amounts correct so don't be afraid to strip it all off and try again. With the heavy chipping coat, it should all come off pretty easily after a good soak in water and not damage the silver base paint layer. Zero77 and Fooesboy 2 Link to comment Share on other sites More sharing options...
NavyMech06 Posted October 24, 2015 Share Posted October 24, 2015 I'm having that same problem with hair spray, two or three thin coats, let it dry overnight or more and still crackle. Link to comment Share on other sites More sharing options...
CATCplSlade Posted October 24, 2015 Share Posted October 24, 2015 Doesn't crackle also have something to do with the paint underneath not being fully cured before covering with a new layer? Link to comment Share on other sites More sharing options...
