My Tribute Trop. MK Vb, HB
  • Please log in to reply
105 replies to this topic
#16 geedubelyer
geedubelyer
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,668 posts
  • Gender:Male
Posted 19 December 2015 - 08:33 AM
Hi Harv, can't help with the decal question sorry. I checked Dennis's thread and read what Edgar had to say on th HB kits. From what I gleaned it is pretty good in many respects but there are one or two things that are a bit..."quirky" apparently. Most notably the ribbed horizontal tails.
Are you going to fix any issues like that or just go right ahead and build this sucker?
Cheers.
  • harvey likes this
#17 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 20 December 2015 - 12:06 AM
Just fooling around.......Harv
  • Barry, MARU5137 and Sparzanza like this
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#18 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 20 December 2015 - 12:17 AM
Cheers.
Thanks. Have the stabs ordered. I do believe there is a glitch with the windshield, we'll see....... I may try to fix things if its not to big a deal. From what I've seen, it should be pretty straight forward.....Harv
  • MARU5137 likes this
#19 Dave Williams
Dave Williams
    Senior Member
  • LSP_Members
  • 2,528 posts
  • Gender:Male
Posted 20 December 2015 - 12:25 AM
I believe the windshield issue in the trop kit is that the Vb trops had the windshield with the internal armor glass, whereas the kit only has the windscreen with the external armor glass.
#20 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 20 December 2015 - 12:28 AM
Hmmmm. I guess we will have to look into that. Anyone have any ideas ?......Harv
#21 LSP_Ray
LSP_Ray
    Senior Member
  • LSP Moderator
  • 9,300 posts
  • Gender:Male
Posted 20 December 2015 - 06:38 AM
IIRC, there is an AM replacement section for the windscreen. I think I have one somewhere. I will see if I can find it in my AM pile. Could take awhile. :hmmm:‚Äč
Posted Image
Ray "Bad Omen" Peterson
#22 dennismcc
dennismcc
    Senior Member
  • LSP_Members
  • 2,621 posts
  • Gender:Male
Posted 20 December 2015 - 09:30 AM
The windscreen is the big sticking point for the V trop, it is correct for the earlier Vb's but not the trop, I am going to try to fit a Hasegawa V windscreen to mine. I have seen someone on here use a Tamiya Mk IX windscreen but that seems way too expensive to me, HPH did a detail set for the kit but it was way too expensive to buy just for the windscreen and they do not appear to have any in stock.
http://www.hphmodels...ale-1-32-detail
Here is a very detailed review of the kit with Edgar's input
http://www.scaleplas...-from-hobbyboss
Cheers
Dennis
Edited by dennismcc, 20 December 2015 - 10:30 AM.
  • harvey and MARU5137 like this
#23 Dave Williams
Dave Williams
    Senior Member
  • LSP_Members
  • 2,528 posts
  • Gender:Male
Posted 20 December 2015 - 11:24 AM
UMM-USA has the HPH set with the windscreen in stock. Alternately, you can try calling Tamiya USA and see if you can buy the clear parts sprue from one of their spitfire kits.
  • harvey likes this
#24 Steve Eagle
Steve Eagle
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 231 posts
Posted 20 December 2015 - 01:28 PM
I used a Tamiya windscreen to make a mould to make a vacuform one.
  • geedubelyer, harvey and MARU5137 like this
#25 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 20 December 2015 - 04:08 PM
Steve, how did it come out? Have any more?
Anyone know if you can re
shape the armour glass and put it on the inside of windshield....Harv
#26 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 20 December 2015 - 06:01 PM
Its a small start. Marking hole locations for Derek's center line bomb rack. Now where did I put my 2mm drill bit ?........Harv
  • geedubelyer, Peterpools and MARU5137 like this
#27 LSP_Ray
LSP_Ray
    Senior Member
  • LSP Moderator
  • 9,300 posts
  • Gender:Male
Posted 21 December 2015 - 12:02 AM
Harv, my set is the HpH set.
For 24 Euros you get a complete new clear resin canopy, resin filler piece so canopy fits correctly, a new cockpit door with separate crowbar, flaps, new horizontal stabilizers, solid wheel covers. You also get outside and inside masks for the canopy.
But, I saw on HpH website they had none in stock.
  • scvrobeson and MARU5137 like this
Posted Image
#28 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,825 posts
  • Gender:Male
Posted 21 December 2015 - 12:20 AM
Ray, Dave mentioned that UMM has it in stock so I'll take a look. It is pricey though and more than I would like to spend. But thanks for the info....Harv
#29 LSP_Ray
LSP_Ray
    Senior Member
  • LSP Moderator
  • 9,300 posts
  • Gender:Male
Posted 21 December 2015 - 05:58 AM
You might check with HpH to see how long it would take to get one from them, and what shipping would be; they are quite a bit cheaper than UMM.
Posted Image
#30 geedubelyer
geedubelyer
    Senior Member
  • LSP_Members
  • 2,668 posts
  • Gender:Male
Posted 21 December 2015 - 07:01 AM
Good luck with the windscreen mod Harv. Re-shaping the armoured glass to fit inside feels like it might be alot of work buddy..... :unsure:
  • harvey likes this
