MOJO Posted November 1, 2003 Share Posted November 1, 2003 for the f4u-1d what are the thoughts on engine color, i've seen several different paint job's. the 2 main ones are gray body, silver or aluminium jugs with black rocker covers---or gray body with all black jugs and rocker covers? also for the corsair fans (you may already know) at www.bentwings.com , they are restoring a fg-1d and have some great photos of the plane in different stages of resto. first post, but always get good tips and ideas from the pros here thanks joe Link to comment Share on other sites More sharing options...
Gene Posted November 1, 2003 Share Posted November 1, 2003 Check out 'Rato' Marczak's excellent article on the build of a P&W R-2800 by Teknics at: https://www.largescaleplanes.com/reviews/review.php?rid=941 Towards the end is included a photo of a nicely restored engine and he compares that with historical evidence. Maybe not the definitive answer you want, but it is a great start! Link to comment Share on other sites More sharing options...
Silverback Posted November 2, 2003 Share Posted November 2, 2003 A question - Is the engine in the Trumeter kit a true -18W with the bolted gearcase, or just the same as in the -1D kit, i.e a -8W with the earlier bullet-nose gearcase? Anyway, for a "factory new" engine: Crankcase, gearcase and distributors in a glossy medium gray. (There's an actual specification for the color, but its not FS595-related, so not much help). I do an eye-ball mix to something close to FS16314 and it looks about right. Cylinders were nautral aluminum with push rod tubes, rocker boxes and baffles in gloss black. Distributor and prop governor in various shades of dary gray and brown. The wiring loom would be dark aluminum or steel colored with wiring either "hi-voltage" red-brown or steel-braid with steel fittings. For "less than factory new": The crankcase , etc. could be ANY dark gray. Cylinders would be darker, but still metallic. Other fittaments could be the original color or painted to match the crankcase. The R-2800 was noted as being a very "tight" engine, so oil contamination would not be much of in evidence. HTH Phil Schenfeld Link to comment Share on other sites More sharing options...
Silverback Posted November 2, 2003 Share Posted November 2, 2003 A question - Is the engine in the Trumeter kit a true -18W with the bolted gearcase, or just the same as in the -1D kit, i.e a -8W with the earlier bullet-nose gearcase? Woops!, I meant ..."Is the engine in the Trumpeter" F4U-4 kit a true -18W..." Inquiring minds wanna know Phil Schenfeld Link to comment Share on other sites More sharing options...
