joe Posted July 22, 2014 Share Posted July 22, 2014 Hey guys, As the title says how do you bend small diameter pipe and keep the shape or cross section of the pipe intact? When I say small what I want to bend is about 3mm internal dia. Link to comment Share on other sites More sharing options...
LSP_Paul Posted July 22, 2014 Share Posted July 22, 2014 Hey Joe, as long as you're not trying to do a 90 degree bend, you can put a smaller piece of solid rod that matches the internal diameter, bend the piece and pull the rod out when you're done. I have done this with aluminum tube with a piece of brass rod inside, made the bend, then pulled out the brass part. The harder inside rod is still bendable, and doesn't allow the external tube to 'pinch" as its bent. For projects where you don't have to have a hollow "inside", just use solid rod. Hope this helps, Paul joe 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 22, 2014 Share Posted July 22, 2014 Paul, how do you pull the internal rod out when it's bent? Oh, and just to clarify: Joe, are you referring to metal pipe (brass/aluminium) or plastic tubing? I think we're all assuming the former. Kev Link to comment Share on other sites More sharing options...
ssculptor Posted July 22, 2014 Share Posted July 22, 2014 There are tube bending devices which are just closely woven coils into which you insert the tube before trying to bend. Micro-Mark has some for about $6. They also have a tube bender machine for a C note ($100 for youse younger guys who dunt no no better) http://www.micromark.com/benders.html I've bought small scale tools from Micro-Mark and am now on their mailing list for life. They have fun stuff. Also here are a few tips on bending small tubes http://www.practicalmachinist.com/vb/fabrication-cnc-laser-waterjet-plasma-welding-fab/bending-small-dis-ss-tube-262780/ Clever techniques, kinda makes me want to try them out. Better than trying to buy benders for $200 and up. Go have fun, Stephen joe 1 Link to comment Share on other sites More sharing options...
joe Posted July 22, 2014 Author Share Posted July 22, 2014 Brass, aluminium or copper at this stage Kev. Link to comment Share on other sites More sharing options...
TonyT Posted July 22, 2014 Share Posted July 22, 2014 could you not fill with it solder then heat it to remove it afterwards? Link to comment Share on other sites More sharing options...
D Bellis Posted July 22, 2014 Share Posted July 22, 2014 Fill the tube with fine sand, bend it, then dump out the sand. Old school, but it works great. HTH, D Bill Cross and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 22, 2014 Share Posted July 22, 2014 Fill the tube with fine sand, bend it, then dump out the sand. Old school, but it works great. HTH, D Wow, that is something I would have never thought of. Great Idea!! Is there any kind of special fine sand one should be using, or is the normal buy-some-@-the-store kind of sand fine enough? Link to comment Share on other sites More sharing options...
Kagemusha Posted July 22, 2014 Share Posted July 22, 2014 Albion Alloys make a tube bender http://scaleplasticandrail.com/kaboom/index.php/all-other-subjects/all-things-tools/75-all-other-tools/634-albion-alloys-ltd-tube-bender Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 22, 2014 Share Posted July 22, 2014 I'm wondering if any of the previous would work for 3mm ID though Link to comment Share on other sites More sharing options...
D Bellis Posted July 22, 2014 Share Posted July 22, 2014 Is there any kind of special fine sand one should be using, or is the normal buy-some-@-the-store kind of sand fine enough? Sand grains fine enough to avoid dimpling the tube from the inside, and small enough to fit within the tube are the only initial requirements. Regular silica 'sandbox sand' is more than small enough for 3mm ID tube. And, as long as the wall thickness isn't paper-thin, it shouldn't dimple it from the inside, either. This method of bending tube has been around for as long as there have been tubes to bend. Just Google "sand bending tube" for a whole bunch more info. D Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 22, 2014 Share Posted July 22, 2014 (edited) For bending small diameter tubing, nothing works as well as their Kadee Trip Pin Bender - works like a charm. http://www.activepowersports.com/kadee-237-trip-pin-pliers-model-train-train-parts/?gclid=CPK7q9yF2r8CFZJr7AodJkIATg Just hold the cursor over the photo for a close up view. I've had mine for nearly 25 plus years and it's super easy to use. Peter Edited July 22, 2014 by Peterpools Link to comment Share on other sites More sharing options...
joe Posted July 23, 2014 Author Share Posted July 23, 2014 Thanks for the discussion and options here gents. This is off topic and not relative to LSP in the case but 1/35 exhaust pipes for a number of king tiger kits I have on the go. The kit supplied exhaust in the Dragon kits are pretty terrible IMO so I was going to have a go at doing my own out of brass or aluminium tubing hence the question. I could drill out the kit parts but they are undersized as they are anyway and metal pipes would look much more convincing. I know Moskit made these but I haven't been able to track any down for years. Link to comment Share on other sites More sharing options...
D Bellis Posted July 24, 2014 Share Posted July 24, 2014 I'd like to see someone pound sand and bend a 3mm tube without kinking. Here ya go: It is standard K&S 1/8" brass tube (actually smaller than the 3mm Joe wants to bend). Probably not as tight a radius as Joe needs for his tank model, although I bent this with just my fingers. A simple pair of wooden dowels in a vice would yield a much tighter and more uniform curve. The sand used was regular beach sand (it is everywhere here), however it was not pounded - just loosely fillied the tube. HTH, D Mal_Belford, Derek B, joe and 1 other 4 Link to comment Share on other sites More sharing options...
joe Posted July 28, 2014 Author Share Posted July 28, 2014 That is very cool and not far off what I'm aiming for. I think with some trial,and error I'll get close. Mal_Belford, D Bellis and Hubert Boillot 3 Link to comment Share on other sites More sharing options...
