JayW Posted January 3, 2017 Share Posted January 3, 2017 Craig - I am just dumbfounded by all the stuff you are doing here! Link to comment Share on other sites More sharing options...
Guyman1 Posted January 3, 2017 Share Posted January 3, 2017 Absolutely beautiful work here Craig it just gets better and better to watch this masterpiece unfold. Guy Link to comment Share on other sites More sharing options...
airscale Posted January 3, 2017 Share Posted January 3, 2017 Craig - I am just dumbfounded by all the stuff you are doing here! me too, and very glad to see you back at it Craig Looks superb Peter Link to comment Share on other sites More sharing options...
AdamR Posted January 3, 2017 Share Posted January 3, 2017 Wow. Just...wow. ~sigh~ Another thread that tells me I should switch to raising hamsters for a hobby. Anybody got some tips on weathering a hamster? Link to comment Share on other sites More sharing options...
Guest Posted January 3, 2017 Share Posted January 3, 2017 No, but if you hums a few bars I might !.....Harv Link to comment Share on other sites More sharing options...
brahman104 Posted January 12, 2017 Author Share Posted January 12, 2017 Thank you for all the kind words Gentlemen, it is indeed good to finally be making a bit of progress on her Sooo, I have been ignoring the bomb bay for quite some time, which is probably because there's lots of shininess (sure that's a word) and details that seem quite complicated. Besides, I'm having a great old time marvelling at how I've managed successfully build a brass "pod" that I can slip in and out of the fuselage to my heart's content..... Unfortunately, that attitude contributes nothing towards overall completion, so I decided I'd have a bit of a poke around at the bay. I still need to be careful about access here, and as much as I would like to close off the top, I'm going to hold out a little longer, but in the mean time I decided to attack the very obvious gusset plates which hold the main trusses together. This goes a long way to hiding my dodgy "plating" over the original brass pieces These little things take ages, and the real bomb bay is full of them. Because I'm adding raised rivets, I have to make a template that is actually the reverse of each junction...... ask me how many times I got that wrong. Looking at the outer racks, I decided that given I'm going to put an auxiliary tank in one side and some bombs in the other, I could probably live with using the kit part, albeit modified (I know you're all wondering if I'm ill......) I also decided on a little artistic license, and made a few of the (what I think are) bomb release solenoids different colours to indicate they may have been swapped out. The same could not be said for the main catwalk/truss thingy. Given that I'd already done the outer sides in litho plate, it would have looked rubbish to slap the kit part in there; well that and the kit part wouldn't fit in my bay This presented a new problem, because it would also look rubbish to "skin" each truss frame with litho as the catwalk can be seen from both sides. Soooo, out came the milling machine and I made a new one (WARNING: GRAPHIC CONTENT OF CRUELTY TO INNOCENT ALUMINIUM) Then it was back to some good old gusset making, except this time there was even more Slowly, but surely, the new 2017 catwalk began to take shape... And for those that thought I'd forgotten the step, I actually had.... One from above, before you never get to see this again. And a few more.. Still plenty to do in here, as you might have guessed there'll be a working light in the bomb bay step as well as a dome light above, there's also lots of cables, boxes and fuel lines to go in there, but with the catwalk in position, it'll be easier to build everything else off it. Oh, and in case you were wondering, the catwalk thus far has taken me four full days to build........ Enjoy! Craig Derek B, Hubert Boillot, Anthony in NZ and 4 others 7 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted January 12, 2017 Share Posted January 12, 2017 Fantastic work Craig ! Hubert Link to comment Share on other sites More sharing options...
brahman104 Posted January 12, 2017 Author Share Posted January 12, 2017 Cheers Hubert! Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted January 12, 2017 Share Posted January 12, 2017 How did I miss this? Incredible work here. And more metal... Where is our hobby headed? Wasn't it called "plastic modelling" once? Brilliant, Craig! Cheers Rainer Link to comment Share on other sites More sharing options...
richdlc Posted January 12, 2017 Share Posted January 12, 2017 shaping up to be a masterpiece Link to comment Share on other sites More sharing options...
chukw Posted January 12, 2017 Share Posted January 12, 2017 Who needs styrene? THIS IS AWESOME!!! Link to comment Share on other sites More sharing options...
Jeff Posted January 12, 2017 Share Posted January 12, 2017 This build is absolutely STAGGERING !!!!!!!!!!!!!!!!!!!!!!!! Incredible talent..... I am in awe.....exquisite..... Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 12, 2017 Share Posted January 12, 2017 Incredible stuff, Craig! Kev Link to comment Share on other sites More sharing options...
tomprobert Posted January 12, 2017 Share Posted January 12, 2017 Sweet Jesus and all things holy! That is astonishing work! Can't wait to see it all with the plumbing installed too. Link to comment Share on other sites More sharing options...
JRutman Posted January 13, 2017 Share Posted January 13, 2017 Uh.......wow? I think that about says it all. J Link to comment Share on other sites More sharing options...
