Microtextile Seat Belts
  • Please log in to reply
17 replies to this topic
#1 A340 Pilot
A340 Pilot
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 302 posts
  • Gender:Male
Posted 08 April 2017 - 12:48 PM
Hi!
What's the best glue to use on HGW's textile seat belts?
TIA
Stein
  • harvey, Peterpools and mpk like this
Luck and superstition wins every time!
In progress: 5x 1/24 Airfix Typhoon.
#2 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,405 posts
  • Gender:Male
Posted 08 April 2017 - 12:50 PM
I just use CA gel to be honest. Just use as small an amount as possible, but they handle it well and stick together nicely if you're careful.
Kev
#3 A340 Pilot
A340 Pilot
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 302 posts
  • Gender:Male
Posted 08 April 2017 - 01:20 PM
Thanks!
  • mpk likes this
#4 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 24,419 posts
  • Gender:Male
Posted 08 April 2017 - 01:50 PM
Thanks Kev
I was using thin CCA and it wasn't working very well
Peter
  • harvey and mpk like this
Trumpeter SBD-1
#5 pcben80
pcben80
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 162 posts
  • Gender:Male
Posted 08 April 2017 - 02:50 PM
I've used Gator's Grip glue for putting these belts together.  Worked very well for me.
Ben
  • Zero77 and mpk like this
#6 Bill_S
Bill_S
    Senior Member
  • LSP_Members
  • 2,606 posts
Posted 08 April 2017 - 03:55 PM
Ben
What Ben said. I clamp the glued portions in a set of locking tweezers until it's nearly dry.
  • Peterpools and mpk like this
I started building my shelf of doom, but I never finished it.
#7 Clunkmeister
Clunkmeister
    Senior Member
  • LSP_Members
  • 11,418 posts
  • Gender:Male
Posted 08 April 2017 - 05:42 PM
I love the HGW belts. I've tried the RB ones, liked them alt too, but HGW is just more available to me.
I only wish they printed both sides like the RB versions. :(
Edited by Clunkmeister, 08 April 2017 - 05:43 PM.
  • A340 Pilot, Peterpools, Zero77 and 1 other like this
Was mich nicht umbringt macht mich stärker
#8 Zero77
Zero77
    Senior Member
  • LSP_Members
  • 5,796 posts
  • Gender:Male
Posted 08 April 2017 - 07:08 PM
PVA glue is certainly the best glue for this kind of job (textile or paper belts). I use the Pacer formula 560, but any other kind of white glue should work nicely. You just have to apply a small drop, you press the belt for a few seconds, clean the excess and it's done. And the belt remains more flexible than with CA.
But i still use CA to glue the belts on the seat.
  • Peterpools, Shaka HI and mpk like this
Following the big Photobucket rip-off attempt, all my pictures on the forum cannot display anymore. I try to reupload the RFI pictures, but i'm not sure i'd have enough time and energy to reupload the pictures of the WIP threads. If you're interested in a specific subject and want me to reupload some pictures, just let me know. :)
Finished : F-16C Barak, F-4J VMF333, Czech Mig-19PM, Bell X-1, Russian Su-25 in Chechnya, Ta152H-1, Czech Avia S.199, Heinkel He162, Swiss AF Bf109G-6, Regia Aeronautica Bf109G-6, P-47D "Slick Chick", RFC Sopwith Pup, A5M2 Claude, Schneider Cup 1926 Macchi M.39, German F-104G JaboG34, Curtiss P-6E, Curtiss P-36A USAAC, Piper SuperCub floatplane (PA-18-150), Russian built Nieuport 11, Albatros D.Va Seefrontstaffel 1, Bf109G-12 (two-seater trainer), Texas ANG F-86D,  Post-war Hawker Tempest Mk.V, Bf109E-3, F-35A 34th FS
#9 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,756 posts
  • Gender:Male
Posted 09 April 2017 - 10:19 PM
I use a water base canopy glue, RC56 for textile based belts
I dont suffer from AMS, I revell in it..get it...Revell
#10 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,419 posts
  • Gender:Male
Posted 09 April 2017 - 11:01 PM
Just soaking in the info
Thanks guys
Peter
  • A340 Pilot and mpk like this
Trumpeter SBD-1
#11 mpk
mpk
    Senior Member
  • LSP_Members
  • 2,927 posts
  • Gender:Male
Posted 10 April 2017 - 01:30 AM
I used Krystal clear the other day. Works well.
Clunk, I just found 5 sets of RB Luftwaffe belts. You need a set?
I was about to order more when I happened to open the correct 109 box. :)
  • Bill_S likes this
My hat has a propellor.
10% faster. ;)
#12 dennismcc
dennismcc
    Senior Member
  • LSP_Members
  • 2,629 posts
  • Gender:Male
Posted 10 April 2017 - 10:07 AM
Kristal Klear for me too.
Cheers
Dennis
#13 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,847 posts
Posted 10 April 2017 - 11:16 PM
Formula 560 Canopy Glue...this is not your grandfather's Elmer's white glue!
#14 CANicoll
CANicoll
    Senior Member
  • LSP_Members
  • 1,391 posts
  • Gender:Male
Posted 11 April 2017 - 05:05 AM
I actually use the very thin CA since I can use just at tiny bit applied with a pin to lock down the seatbelt and the buckle if I need to or to attach the pad to the back of the buckle.  I use thicker CA for attaching the PE to the seat or frame unless the attachment point is very noticeable, then I go back to the very thin CA and the pin.
Have not used the water based/canopy glue before but will try it now...
Chris
  • Zero77 and Shaka HI like this
#15 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,847 posts
Posted 11 April 2017 - 06:29 AM
I have, too. But 560 is very forgiving and it works fast and stays put.
  • Zero77 likes this
