imatt88 Posted February 25, 2018 Share Posted February 25, 2018 Hey all, With the excellent tweak list just posted, is there any mods that need to be made to the kit to make the Polish Lim 6 version? Thanks, Ian Link to comment Share on other sites More sharing options...
Rob Owens Posted February 25, 2018 Share Posted February 25, 2018 Major mods will include the parachute housing at the base of the fin, and wing pylons for Mars-2 rocket pods. Try googling "Lim-6 Images" Link to comment Share on other sites More sharing options...
imatt88 Posted February 25, 2018 Author Share Posted February 25, 2018 Rob, Cool, thanks Link to comment Share on other sites More sharing options...
thierry laurent Posted February 25, 2018 Share Posted February 25, 2018 Get the cheap MMP booklet. It has scale plans of all the Lim versions. It also has 1/32 scale plans of the "basic" MiG-17F version. Hth Thierry Kagemusha 1 Link to comment Share on other sites More sharing options...
imatt88 Posted February 25, 2018 Author Share Posted February 25, 2018 Nice! I'll look for it. Thanks Link to comment Share on other sites More sharing options...
imatt88 Posted February 25, 2018 Author Share Posted February 25, 2018 Anyone know of aftermarket goodies for this kit? I've seen the photo etch bits, but that's about it.. Cheers, Ian Link to comment Share on other sites More sharing options...
thierry laurent Posted February 25, 2018 Share Posted February 25, 2018 The AMS cockpit is highly recommended as well as the Eduard photoetched set. Profimodeller sets: there are at least a dozen of resin and photoetched sets! Most but not all of them may be found in a Superset. I would not recommend the engine one as it does not correct the exhaust. The panel one is nice but not fully accurate. Neither Eduard nor Profimodeller give accurately shaped main landing gear doors but they are far better than the kit ones. Same situation for the Profimodeller sets for the airbrakes or the wing fences. They are again far better than the kit ones but not far more accurate regarding the shapes. Note there is nearly no part redundancy between Eduard and Profimodeller sets. I also recommend the guns and pitots tube sets. The Squadron canopy for the MiG-15 is recommended. It is not fully accurate as the canopy of the 17 was a little bit flatter but this stays the best option has the kit one is very bad and the windscreen is nearly beyond relief. The Greymatter tail corrects most tail and rudder issues and can be a time saver solution if you close the airbrakes. If you want to open them and correct them at least a little bit, I do not recommend the set as it will complicate a lot the assembly. Hth Thierry Harold 1 Link to comment Share on other sites More sharing options...
imatt88 Posted February 25, 2018 Author Share Posted February 25, 2018 Yes it does, thank you Link to comment Share on other sites More sharing options...
K5IKL Posted February 26, 2018 Share Posted February 26, 2018 Do you need any wheels to replace the rubber junk? I have some spares. Jerry Link to comment Share on other sites More sharing options...
