ClumsyDude Posted September 28, 2015 Share Posted September 28, 2015 Awesome work. The paint is really neat, can't wait to see what you do with that resin exhaust. I've long admired the detail in that item. Jim Gelerth 1 Link to comment Share on other sites More sharing options...
Zero77 Posted September 28, 2015 Share Posted September 28, 2015 That's a great WIP. There's never enough soviet made aicraft ! Gelerth 1 Link to comment Share on other sites More sharing options...
Macbain Posted September 30, 2015 Share Posted September 30, 2015 Very nice job on a very cool subject. Keep it up! Gelerth 1 Link to comment Share on other sites More sharing options...
Rainer Hoffmann Posted September 30, 2015 Share Posted September 30, 2015 Those wheel bays look terrific. Are they the kit parts or did you add some scratch built parts? Cheers Rainer Gelerth 1 Link to comment Share on other sites More sharing options...
Gelerth Posted September 30, 2015 Author Share Posted September 30, 2015 :popcorn: I hope you will find something nice or usueful here. Awesome work. The paint is really neat, can't wait to see what you do with that resin exhaust. I've long admired the detail in that item. Jim Thank you. Details are really good on the exhaust but I'm still wonder how am I gonna to paint this. That's a great WIP. There's never enough soviet made aicraft ! True. I have only MiG-29 completed so I hope soon he will get a good comrade. Gelerth.. the cockpit and the ejection seats look SPLENDID...MAGNIFICENT.. job.. looking every inch like a Soviet aircraft. . I like your "provisional" drawing of the base ... any further ideas on that. Thank you. . Thank you. Weel I have few ideas... but I will reveal them later - I hope you will be suprised. Very nice job on a very cool subject. Keep it up! Thank you. Those wheel bays look terrific. Are they the kit parts or did you add some scratch built parts? Cheers Rainer Thank Rainer. Wheel bays are resin from Aires - they already look amazing so I didn't add anything to them. Ok. Back to work. I corrected a rear part of S-24B rocket as kit provided a flat cap at the end: Finally I glued canopy and of course I had to used some putty: Also I clean up a metal struts and join them with plastic parts: Do you guys have any good photos of undercarriage? I would like to add some wiring. I'm not sure if I will use it but I started a cart: And on the end, almost completly scrached plaster board - i will use it as a pattern and cast some more: andromeda673 1 Link to comment Share on other sites More sharing options...
Gelerth Posted October 3, 2015 Author Share Posted October 3, 2015 Lately I mostly worked on base. It all started from the main element of monument: Will it fit or not?: Later I've add some minor parts: andromeda673 1 Link to comment Share on other sites More sharing options...
Gelerth Posted October 3, 2015 Author Share Posted October 3, 2015 But I wasn't completely satisfied so I added some more: Some new bricks elements: And right now it looks like this: Now I will have to copy some of the plaster elements and do some cut-fit-cut-glue magic. dutik, mywifehatesmodels and andromeda673 3 Link to comment Share on other sites More sharing options...
ClumsyDude Posted October 3, 2015 Share Posted October 3, 2015 Great work Gelerth, love the base. Jim Gelerth 1 Link to comment Share on other sites More sharing options...
Loic Posted October 4, 2015 Share Posted October 4, 2015 Very nice ! Gelerth 1 Link to comment Share on other sites More sharing options...
Gelerth Posted October 5, 2015 Author Share Posted October 5, 2015 Great work Gelerth, love the base. Jim Thank Jim. Very nice ! Thank you. Works continues. First I dear how I would like to set up a monument: Then I started to realize my idea by placing pavements and putting some small stones on one of the path: In the meantime I glued air intakes: I wanted to build engine as an option to open the plane and show it but I decided not to - it is too risky that plane will open by itself, so I will paint it and glue all parts in place. andromeda673 1 Link to comment Share on other sites More sharing options...
Gelerth Posted October 7, 2015 Author Share Posted October 7, 2015 Some more photos of base with more rocks. I've noticed that they are too big, so I will put some smaller on top. Also I prepared land for grass. It was made from plasticine, then some water based glue and earth from my garden: Now I will have to paint pavement, plant some grass and almost done. I paint also the interior parts of engine, but they won't fit into the exhaust, I almost broke down the very fragile resin rings and etched construction to hold them together. Finally I was able to slide it in and glue in place. Engine is ready for painting now: I glued "teeth" as vortex genarators but they look odd to me: Without tail, plane looks like a spaceship from Star Wars: zak, andromeda673 and mywifehatesmodels 3 Link to comment Share on other sites More sharing options...
ClumsyDude Posted October 7, 2015 Share Posted October 7, 2015 Looks great, I love that base. On the fuselage, there are two lines of rivets parallel to each other on the spine, either side of where the front half joins the rear. It's hard to tell if they are parallel, or if it's a trick of perspective that makes them look not to be? Either way your work is really neat and impressive, far better than I can manage. Cheers Jim Gelerth 1 Link to comment Share on other sites More sharing options...
John F Smith Posted October 7, 2015 Share Posted October 7, 2015 Great project! Wheel wells and 'pit looking exceptionally good. Great idea for display, too! John Gelerth 1 Link to comment Share on other sites More sharing options...
Gelerth Posted October 8, 2015 Author Share Posted October 8, 2015 Looks great, I love that base. On the fuselage, there are two lines of rivets parallel to each other on the spine, either side of where the front half joins the rear. It's hard to tell if they are parallel, or if it's a trick of perspective that makes them look not to be? Either way your work is really neat and impressive, far better than I can manage. Cheers Jim Thank you Jim. I think that curve of the fuselage makes this optical ilusion cause lines are parallel - but thank for pointing this out. Great project! Wheel wells and 'pit looking exceptionally good. Great idea for display, too! John Thank you John. Link to comment Share on other sites More sharing options...
phantom Posted October 8, 2015 Share Posted October 8, 2015 What color did you use for the cockpit? Mike Link to comment Share on other sites More sharing options...
