Hardcore Posted June 14, 2017 Share Posted June 14, 2017 (edited) It is so easy to buy Meng`s little kits. They are cheap and cute. What's not to like? I have ordered the king tiger too. The quality of the tiger 1 suggest that that one will also be a hit.The tiger is small, with minimum number of parts, so I figured it is perfect opportunity to test colors and techniques (or actually learn to paint for real...)After assembly I grabbed the only available gray color at hand, a Vallejo panzer gray Primer(sic).This will show through the chipping as steel. It may too dark but I don't care much. I wouldn't delay the build.Next I sort of dry brushed chipping fluid were it looked suitable. The idea is to get more control over the process from the beginning. (I put nothing on the wheels) Actually the method i originally intended to test was to airbrush the fluid on select areasOver this I sprayed Tamiya dark yellow, followed by a second coat with a DY+WHITE+BUFF mix I read about somewhere on the web.After this I turned to the tracks. I had no flat black so Vallejo's Primer, which is quite dark, was fed to the AB once more.At this point I took a break to go home, read some more on Weathering and rummage around for colors simulating dust and rust.It is ironic but it will be the first tank i ever finish. PS. the kit code is MNGWWT-001 if you want to go buy it. Edited June 14, 2017 by Hardcore Shawn M, Joe66 and Bill Cross 3 Link to comment Share on other sites More sharing options...
Shawn M Posted June 15, 2017 Share Posted June 15, 2017 (edited) I love this line of kits, they build so damn easily and are just cute and fun! Edited June 15, 2017 by Shawn M Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 15, 2017 Share Posted June 15, 2017 Neat! Im not much for armor, but something like this might well be a good change of pace.................Ive always LOVED the TII/KIng Tiger! Shawn M 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 15, 2017 Share Posted June 15, 2017 Where to order the King Tiger from? Link to comment Share on other sites More sharing options...
dutik Posted June 15, 2017 Share Posted June 15, 2017 Tiger, Tiger in the night? Is there a Mentalist anywhere? Nice little model Regards - dutik Link to comment Share on other sites More sharing options...
Hardcore Posted June 15, 2017 Author Share Posted June 15, 2017 (edited) Thank you guys, and apologies to the poet W. Blake. Edited June 15, 2017 by Hardcore Link to comment Share on other sites More sharing options...
Hardcore Posted June 17, 2017 Author Share Posted June 17, 2017 Disaster! The tracks does not fit the running gear! Annoying, and no practical solution. I could narrow the drive wheel but then the running wheels won't fit. Well, i 'keep calm and carry on'. The next step was to apply rust color. Next step will be to mask and paint gun metal for the worn surfaces. Link to comment Share on other sites More sharing options...
Hardcore Posted June 17, 2017 Author Share Posted June 17, 2017 I very much think that's why Meng have no teeth on the drive sprocket. With that soft rubber track the longer unsupported edge would no doubt roll over and curl up. I think they made the decision to re jig the fit if the tracks to work/ fit the running gear they had. That's one reason I went with replacing the tracks. The other is that I'm certifiably insane. Looking foreword to seeing more pictures of your paint job. Hm, I could file them down completely on the rubber side. Link to comment Share on other sites More sharing options...
Hardcore Posted June 21, 2017 Author Share Posted June 21, 2017 (edited) Painting tow cables is tiresome since they are not moulded separately. Took me over an hour to do it, but then I was discusing politics at the same time with members of the club.I managed quite well considering my tendency to shake and will rely on the wash to cower my mistakes:) Speaking of mistakes my idea of dry brushing on chipping fluid didn't work that well. Perhaps the Tamiya paint was not very permeable, or the two coats was one too much, or I may have not been generous enough with the fluid. I suspect the former (you can see traces of the fluid under the paint here and there) .The paint job took a beating when scrubbing with water. I hope that will work in my favor over time. I gave the thing some future with the AB to avoid getting a too dry surface for the oil wash. That's what make it look darker. Decals worked well but where not quite in register. NVM. Next week I will wash it. I have a green brown panel wash I may try! Edited June 21, 2017 by Hardcore Shawn M and dutik 2 Link to comment Share on other sites More sharing options...
Shawn M Posted June 22, 2017 Share Posted June 22, 2017 ooooo nice! I caved and orderd the King Tiger to keep my sherman company Out2gtcha 1 Link to comment Share on other sites More sharing options...
Hardcore Posted June 23, 2017 Author Share Posted June 23, 2017 In comparison the Tigers are bigger models. You may want to buy another Sherman, or four, to even out things a bit. Shawn M 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 23, 2017 Share Posted June 23, 2017 ooooo nice! I caved and orderd the King Tiger to keep my sherman company Im not usually a "cute" modeler, but the Tiger II has always been my favorite tank. I couldnt see where to order it, where do you order it from?? Link to comment Share on other sites More sharing options...
Shawn M Posted June 23, 2017 Share Posted June 23, 2017 (edited) I got my mine from Sprue Brothers Brian http://store.spruebrothers.com/product_p/mngwwt003.htm Edited June 23, 2017 by Shawn M Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted June 23, 2017 Share Posted June 23, 2017 I got my mine from Sprue Brothers Brian http://store.spruebrothers.com/product_p/mngwwt003.htm Thanks! I checked SB a while back and it was not in stock Link to comment Share on other sites More sharing options...
Hardcore Posted June 23, 2017 Author Share Posted June 23, 2017 This page have a couple of shots of the unpainted model. http://www.86daigou.com/p/3GMENGWWT003de-guo-hu-wang-zhong-xing-tan-ke-bao-shi-jie-pao_547633316526 Out2gtcha 1 Link to comment Share on other sites More sharing options...
