Gloster Gladiator Mk I Silver Wings 32-008
  • Please log in to reply
31 replies to this topic
#1 Jamme
Jamme
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 1,162 posts
  • Gender:Male
Posted 02 May 2011 - 05:14 PM
Hello Everybody.
I received my kit's today (Thank you Doug) and I was really excited to open the well packed box from Silver Wings, as this will be my first resin kit!.
I didn't make a KR as other members here on LSP already did.
At the look of the content, I decide (with the help of myself :BANGHEAD2: ) that I had to start it immediately.....
Who says one more? :ph34r:
I took the engine block and had too change somme stuff.
On the picture you see black pencil lines, those are for the later job.
Posted Image
I then removed the bolts in the middle of the block
Posted Image
Put new bolts made with an hexagonal Punch and Die:
Posted Image
I then removed and replaced the front bolts:
Posted Image
I then replace the wire with monofilament HO wire and remade two small rundels (onthe support?)
Here two pictures of the (for the moment...) finished job:
Posted Image
Posted Image
That's all for the moment.
A little start....
Thank you for looking.
Comments, critics always welcomme!
Cheers,
Jamme
Edited by Jamme, 25 May 2011 - 05:28 PM.
Cheers,
Jean-Marie (Jamme)
#2 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 3,752 posts
  • Gender:Male
Posted 03 May 2011 - 01:34 AM
Great start on that engine, looks even better with the added details. Well done! :speak_cool:
#3 LSP_Ron
LSP_Ron
    Senior Member
  • LSP Moderator
  • 16,468 posts
  • Gender:Male
Posted 03 May 2011 - 01:36 AM
Looking good!
Ron
I love deadlines. I like the whooshing sound they make as they fly by.
Douglas Adams
When I die, I'll be on time
#4 Qvarre
Qvarre
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 283 posts
  • Gender:Male
Posted 03 May 2011 - 08:14 AM
Thatīs a nice start you got,Iīm worried over how the eningine will fit into the covers, have you tested that?I will try to assamble the engines bigger part without glue and testfit the covers so thereīs no surprices comming up when the times for the glue comes.
//Larsa
#5 Jamme
Jamme
    Senior Member
  • LSP_Members
  • 1,162 posts
  • Gender:Male
Posted 03 May 2011 - 09:41 PM
Hello Everybody.
Thank you Frank, Ron and Larsa for your nice comments.
For Larsa:
I'm worried too. I didnt tes fit the engine, and think it will be OK. But......I don't know in your kit, but in mine, the two parts of the cover are not too round. Diameter of the two parts are not the same... I think it will go, but that worries me.
Wait and see......
I had a little time to spend on this build this evening and here are the results and a little UP!
So those are the cylinders heads, the exhaust parts en what I think are the Pushrods.
There are 9 cylinders in all:
Posted Image
Looking from closer there is flash on the cylinders;
Posted Image
I began to clean them and tryed (not perfect but it's OK for me) to have them look better. Those are the tools I used for it.
Posted Image
A picture with three heads already cleaned and put in place:
Posted Image
Work began.
You can see the amount of resin that has to be cleaned (not so much anyway, but....)
Posted Image
Cheers,
Jean-Marie (Jamme)
#6 Jamme
Jamme
    Senior Member
  • LSP_Members
  • 1,162 posts
  • Gender:Male
Posted 03 May 2011 - 09:42 PM
I started removing the flash where the part goes on the block:
Posted Image
I removed the "sparkplugs" and drilled a 0,3mm hole instead as I will put wires:
Posted Image
I also removed the two "tubes" on the front of the cylinder that normally go (at lest I think..) at the ring oil or air cooler (not included in the kit) in the front of the engine cover.
Will be replaced later....
Posted Image
Everything was then cleaned as best as I could ( wings of cylinders, etc) and this is one finished....(8 more to go :BANGHEAD2: )
Posted Image
When all 9 cylinders are finished they are glued in place and I must admit that the fit and the look is not bad:
Posted Image
Posted Image
So that's it for tonight.
I have a question for the Mercury IX engine. The instruction says the block semi mat black (what I agree), but they say the cylinders should be Flat black.....Shouldn't they be Metallic (I meen silver)??
Thank you for your answers.
Comments and critics always welcomme!
Cheers,
Jamme
Cheers,
Jean-Marie (Jamme)
#7 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 7,926 posts
  • Gender:Male
Posted 03 May 2011 - 09:48 PM
Very sharp, Jamme.
Sincerely,
Mark
#8 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,091 posts
  • Gender:Male
Posted 03 May 2011 - 10:24 PM
Nice engine Jamme. Good work.
Kev
#9 LSP_Ron
LSP_Ron
    Senior Member
  • LSP Moderator
  • 16,468 posts
  • Gender:Male
Posted 03 May 2011 - 11:11 PM
I've seen pictures of the engine done both ways. I am not sure which is correct, I'd lean toward both being correct....
LINK
Posted Image
Posted Image
Ron
Douglas Adams
#10 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 3,752 posts
  • Gender:Male
Posted 04 May 2011 - 03:12 AM
That's a lot of work you put into those cylinders, and it really shows. Nice work!
#11 AndersN
AndersN
    Senior Member
  • LSP_Members
  • 964 posts
  • Gender:Male
Posted 04 May 2011 - 04:45 AM
Really nice!
Anders
#12 Qvarre
Qvarre
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 283 posts
  • Gender:Male
Posted 05 May 2011 - 03:02 PM
Nice way to start up the build.Iīll start up my build with the interior so all others have something to watch, and I will watch your work on the engine closley.
//Larsa
#13 Jamme
Jamme
    Senior Member
  • LSP_Members
  • 1,162 posts
  • Gender:Male
Posted 05 May 2011 - 10:51 PM
Hello Everybody.
Thank you Mark, Kev, Ron (Special Thanks for the pictures),Anders en Larsa for your nice comments.
I had a litlle time this evening, so I decided a would made a little UP!
First of all, I put the pushrods on the engine.
For those building this kit, I will say be carefull when removing the rods from theyr tree.
Anyway they are to short (somme) so I had to made a roundel in plasticard (you see them as it's white plasticard)
Posted Image
As my kit has missing engine pieces (already asked Wotjek, and he will send them, very good service!), I had a little work on the cover. It comme in 2 pieces:
Posted Image
Be carefull when assembling because the 2 parts have not the same radius:
Posted Image
When assembled you can see that it isn't quite round.....
Posted Image
I removed 0,5mm each side to make it fit.
There is also somme flash where the 2 parts go togheter and where you later, have to put somme photoetch..
Posted Image
After sanding everything smooth ( inside) I removed the pins (that goes in the fronf part of the cover and replaced them with 1,2mm rod:
Posted Image
Cheers,
Jean-Marie (Jamme)
#14 Jamme
Jamme
    Senior Member
  • LSP_Members
  • 1,162 posts
  • Gender:Male
Posted 05 May 2011 - 11:01 PM
Before sanding the exterior smooth and because of the mold lines, I made a pattern using somme Tamiya tape, so I can make
nieuw parts in plasticard:
I place the tape, pushing the tape on the border with a toothpick
Posted Image
Then with a pencil a go along the edge. After I remove the tape and I have my "master":
Posted Image
I now can sand everything smooth:
Posted Image
I made a little dryfit of the engine inside his cover and with the fron ring.
Everything fits......OUF!
Posted Image
I also started on the engine exhaust, painting them mat black, before making them "Rusty", but that's for another day.
Posted Image
Comments and critics always welcomme.
Cheers,
Jamme
Cheers,
Jean-Marie (Jamme)
#15 OldTroll
OldTroll
    Senior Member
  • LSP_Members
  • 888 posts
  • Gender:Male
Posted 06 May 2011 - 12:17 AM
Exceptionally fine build already. I will be referring to this build when I start mine.
