LSP_Kevin Posted April 16, 2013 Share Posted April 16, 2013 Looks like you've got some challenges Karl! But we all know you're up to it. Kev Link to comment Share on other sites More sharing options...
blackbetty Posted April 17, 2013 Author Share Posted April 17, 2013 (edited) i hope so, kevin one problem are the gunports. they dont look like on the photos. on the left i have started to drill them out. Edited April 17, 2013 by blackbetty Link to comment Share on other sites More sharing options...
blackbetty Posted April 17, 2013 Author Share Posted April 17, 2013 on the real thing there are covers screwed aropund them to create the opening, so i trased these on a pice of thin paper, scanned and drew them in illustrator. then i cut them from vinyl foil. they are not easy to cut because they are so small. Link to comment Share on other sites More sharing options...
blackbetty Posted April 17, 2013 Author Share Posted April 17, 2013 stuck on an primed, some rivets added: Link to comment Share on other sites More sharing options...
blackbetty Posted April 17, 2013 Author Share Posted April 17, 2013 to get the intakes straight i made a small cut on the bottom and inserted a strip of sheet the lift the rear part up Link to comment Share on other sites More sharing options...
blackbetty Posted April 17, 2013 Author Share Posted April 17, 2013 ...and some more sheet to close the gap inbetween Link to comment Share on other sites More sharing options...
Guest Peterpools Posted April 17, 2013 Share Posted April 17, 2013 Karl Nice progress on the troublesome intakes. Looking forward to how this area comes out after the basic assembly is done. Keep 'em coming :popcorn: Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 thanx peter! looking at the intakes i really wasnt satisfied Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 the instructions want you to glue the intake trunks to the lower wing, a real nightmare to fit them to the intakes afterwards. so i cut them off again. here they are in the fuselage Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 next i cut off the inner trunk part again and discarded it Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 (edited) the fuselage side is completey flat and void of any seams, so i cut a piece from very thin card Edited April 22, 2013 by blackbetty Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 this was glued to the side of the fuselage after i thinned down the parts Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 much better Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 the outer intake part needs a lot of work to sit properly against the fuselage Link to comment Share on other sites More sharing options...
blackbetty Posted April 18, 2013 Author Share Posted April 18, 2013 some spacer on the rear should remove the gap Link to comment Share on other sites More sharing options...
