DrDave Posted April 26, 2005 Share Posted April 26, 2005 Here we go! My first effort. The Azur I 16 finished with Data Decals spurious Mig 3 markings. Dont be too harsh! Cheers Dave Pogson Link to comment Share on other sites More sharing options...
DrDave Posted April 26, 2005 Author Share Posted April 26, 2005 what a rotten picture! Link to comment Share on other sites More sharing options...
DrDave Posted April 26, 2005 Author Share Posted April 26, 2005 try again Link to comment Share on other sites More sharing options...
DrDave Posted April 26, 2005 Author Share Posted April 26, 2005 and below Link to comment Share on other sites More sharing options...
DrDave Posted April 26, 2005 Author Share Posted April 26, 2005 just noticed I bent the pitot! Bugger! Link to comment Share on other sites More sharing options...
D Bellis Posted April 26, 2005 Share Posted April 26, 2005 Looks good to me! Â What paint & decals did you use? Â D Link to comment Share on other sites More sharing options...
Denie Posted April 26, 2005 Share Posted April 26, 2005 Hi Dave  Nice touch on the weathering.  Denie Link to comment Share on other sites More sharing options...
DrDave Posted April 26, 2005 Author Share Posted April 26, 2005 Its the data decals Mig 3 set. I tried but failed to get Adam to make the I16 set he planned. Tamiya light blue and deep green acrylics. Tamiya smoke, an oil wash, polyscale dust and dirt with a final coat of extracrylix flat varnish. The Azur kit is lovely. I did not find any of the fit problems reported but the resin gunsight is as fiddly as a fiddling fiddler fiddling with his fiddle. I know the I16 did not often wear upper wing stars, but I just liked the look. Dave Link to comment Share on other sites More sharing options...
DrDave Posted April 28, 2005 Author Share Posted April 28, 2005 few more Link to comment Share on other sites More sharing options...
DrDave Posted April 28, 2005 Author Share Posted April 28, 2005 again Link to comment Share on other sites More sharing options...
Erwin Posted April 28, 2005 Share Posted April 28, 2005 Looking real good ! Link to comment Share on other sites More sharing options...
Koala Posted April 28, 2005 Share Posted April 28, 2005 Nice one. Definately one I'd like to have on my shelf! Link to comment Share on other sites More sharing options...
DrDave Posted April 28, 2005 Author Share Posted April 28, 2005 You need nanotechnology to assemble the gunsite! The seat sits too far forward on its mount. Should nearly abut the rear bulkhead. Shave 1mm of each side of the cockpit floor. Mounting the instrument panel is tricky too. When you finally join wing to fuselage, do it with the cowl ring on as it widens the fuselage marginally to fill any gap. Join the wing in 2 stages, rear first, let the glue set, then liquid poly the front the next day. fits fine after that. Assemble the undercarraige before installation as it is really fiddly with inadequate location points. Enjoy though, its a great kit! Dave Link to comment Share on other sites More sharing options...
guiterahome Posted April 28, 2005 Share Posted April 28, 2005 I am currently assembling it : fit problem with the wings (you have to use putty) Link to comment Share on other sites More sharing options...
DrDave Posted April 28, 2005 Author Share Posted April 28, 2005 Not on mine, using the trick of doing front and back 2 stages with liquid poly. The underfuselage to wing join needs Mr surfacer, true. But that area is easy to sand down ! Link to comment Share on other sites More sharing options...
