richdlc Posted December 18, 2017 Share Posted December 18, 2017 nice work Peter for what it's worth the two canisters either side of the pilot's seat are smoke grenades and as such would be painted whatever colour smoke grenades are painted.. Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 19, 2017 Share Posted December 19, 2017 Thanks Rich, I've been trying to find out what they actually are. If off to my Pal Google and find out what color smoke grenades the Navy used in 1940. Peter Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 19, 2017 Share Posted December 19, 2017 Peter, Hope this helps, https://maritime.org/doc/pyro/index.htm Paul RLWP 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 19, 2017 Share Posted December 19, 2017 Paul Holy Cow - what a goldmine Thanks so much for the link Peter Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 19, 2017 Share Posted December 19, 2017 Peter, Hopefully it wasn't a blind path..I figured if you're going to find info on WWII US Pavy pyro...thats probably a great place to start Paul Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 19, 2017 Share Posted December 19, 2017 Amazing OOB work Peter! Sometimes that can be a really refreshing way to go. Model on! Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 20, 2017 Share Posted December 20, 2017 Thanks Paul Loads of info and a link that will be invaluable for future projects Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 20, 2017 Share Posted December 20, 2017 Thanks Brian Great change of pace and thoroughly enjoying the build. Agreed 100% for sure. Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 23, 2017 Share Posted December 23, 2017 UPDATE: 12/23/17: THE FRONT OFFICE: TEST FITTING ALL THE ASSEMBLIES. Making steady progress on the front office – both the pilots office and the gunners area as well. All the major interior sub assemblies are pretty well completed at this point with quite a bit of hand detail painting to go and then additional Tamiya Panel Line Washes will be needed to bring out the details. I've been very careful to complete each assembly as per the kit instructions, strictly adhering to IPMS Box Stock rules; as care has to be exercised as not to alter or upgrade any of the parts with even small bits and pieces that are not included in the kit. So far I have been very pleased as to what Trumpeter has put in the box, considering the Dauntless is one of their earlier kits. Parts are well molded, flash has been at a minimum and the fit has also been very good. I've devoted as much time to polishing, priming and shooting AK Aluminum over Mr Color Gloss Black and then toning down the NMF with MRP Semi Matt, as to actually building the kit. Overall, I'm quite happy with the interior, which replicates a well maintained aircraft but it still looked a bit to natural aluminum in color rather then one painted with aluminum lacquer paint for the period. I've decided to switch gears a bit and toned down the interior finish to better replicate a painted lacquer aluminum, with a mix of MRP Matt and Semi Matt clear. For the exterior, I'm now planning on going with Tamiya AS-12, representing the same type of aluminum lacquer painted finish and thinking the fuselage paint would have looked a bit different then the interior due to some fading and lots of waxing - after all, this being the commander's aircraft and congressional appropriations were always at a low level. My Yellowhammer Decals arrived the other day: set #YHD32016 and they are beautifully done. The painting guides are first class and the decals look dead on the money. Of course I forgot to take a photgraph of the decals but I'll do a few a bit later on. The .30 Cal MG was built per the kit with the PE sight, finished with AK metallics and Uschi Polishing Gun Powder. I decided to leave the MG off until the last possible minute as it's quite fragile and I'm 100% positive I would break it more then once during the painting stages if I added it now. The ADF antenna is almost done and ready to be added. So far, I'm having a ball building the SBD Box Stock and figuring out ways to add some extra life without violating the rules. Next Up: Gluing up the fuselage and then the big radial. Thanks for checking in Peter Link to comment Share on other sites More sharing options...
dora9 Posted December 23, 2017 Share Posted December 23, 2017 (edited) Nice work! Can't wait to see the fuselage closed! Mine will be the Midway Madness Survivor SBD-2 from Yellow Wings decals. Edited December 23, 2017 by dora9 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 23, 2017 Share Posted December 23, 2017 Way to Go Peter! With good detail painting and washes like you've done, one can really see just how well detailed a model can appear OOB. Keep up the great work! Paul Link to comment Share on other sites More sharing options...
dennismcc Posted December 23, 2017 Share Posted December 23, 2017 Looking great Cheers Dennis Link to comment Share on other sites More sharing options...
Out2gtcha Posted December 23, 2017 Share Posted December 23, 2017 Well that is just lovely! Link to comment Share on other sites More sharing options...
monthebiff Posted December 23, 2017 Share Posted December 23, 2017 Very nice work Peter, going to be a stunner when its finished in all of its yellow winged glory! Regards. Andy Link to comment Share on other sites More sharing options...
Gazzas Posted December 23, 2017 Share Posted December 23, 2017 I like it Peter, I like it! Gaz Link to comment Share on other sites More sharing options...
