Haggis Posted August 15, 2006 Share Posted August 15, 2006 Hi chaps, I am doing the Trumpeter Wellington at the moment and there are many areas of natural wood in the aircraft. I remembered Jay's article when he did that WWI German thingy (sorry, haven't a clue on the stuff) and he used oil paints. I didn't use iol paints on this for two reasons, the first is that this is for Jay's mag and I have a really tight deadline and oil paints can take a while to dry, and the second is I don't have any oil paints! I undercoated the areas in Gunze RLM 79 sand but any semi gloss light brown colour will do. Then I wet dry brushed (if that makes sense) the darker brown, for this I used Vallejo Dark Earth (given a few shakes in the bottle but not too much. The semi gloss undercoat really helps making the top coat slide on. The brush I used was one of the kids really crappy old bristly things, for this technique the worse the brush is the better. I really like the effect using these paints and they dry in about 10 minutes to a semi gloss sheen which really looks like varnished wood. Link to comment Share on other sites More sharing options...
Haggis Posted August 15, 2006 Author Share Posted August 15, 2006 Here's the rest of the wood bits. Link to comment Share on other sites More sharing options...
Haggis Posted August 15, 2006 Author Share Posted August 15, 2006 Here's the rest of the fuselage just for interests sake. Shame none of the wood is going to be visible. Link to comment Share on other sites More sharing options...
stusbke Posted August 15, 2006 Share Posted August 15, 2006 makes sence the way you explained it and teh undercoat being wet also but how long should we wait until we start drybrushing the darker top coulor on it a few minutes? Looks great for sure Wil try this later on on a diorama I use to sand the wooden parts with a verry rough sanding paper and that makes the grain of the wood also then painbt it like you explained and wash it with a dark color and voila Greetz STB Frederick Jacobs Link to comment Share on other sites More sharing options...
Haggis Posted August 15, 2006 Author Share Posted August 15, 2006 Hi Fred The undercoat should be dry, by the time you have cleaned the airbrush the Gunze paint is ready for the top coat. Link to comment Share on other sites More sharing options...
The Phantom Posted August 16, 2006 Share Posted August 16, 2006 Haggo, It seems such a shame, might be worth putting a couple of LED's in there in the crew positions for lighting it up for special occasions, you would at least see the interior in the lightin environment it was for not much time and effort. Phantom Link to comment Share on other sites More sharing options...
Smokinguns3 Posted August 16, 2006 Share Posted August 16, 2006 Now thats a great idea on how to do wood grain i think that has to be the hardest thing to simulate. And is that an injector pin i see Jamie ? Link to comment Share on other sites More sharing options...
Haggis Posted August 17, 2006 Author Share Posted August 17, 2006 And is that an injector pin i see Jamie ? Typical Trumpeter. You can't see bugger all in there anyway! Link to comment Share on other sites More sharing options...
Astro32 Posted August 17, 2006 Share Posted August 17, 2006 Dang it, Jamie! I'm jealous! Really great! That's the best painted wood effect I've seen! And how is the rest of the Wellington kit so far? I do have a question: the fabric showing between the geodesic structure. Was it painted silver? or did the primer or fabric color show through? It's not really visible anyway, but nonetheless I'm curious. Regards, Ross Link to comment Share on other sites More sharing options...
Haggis Posted August 26, 2006 Author Share Posted August 26, 2006 Hi Ross. The age old question. Some say the fabric was painted red primer on the outside which leached through leaving a pinky effect. Some others say that the hole interior had a silver dope painted over the whole thing, either way the metal bits were aluminium. I went all over aluminium as its a lot easier and quicker. Link to comment Share on other sites More sharing options...
Erwin Posted August 28, 2006 Share Posted August 28, 2006 Hi, When doing a wooden prop,I first paint it with Humbrol 'natural wood'. Later when dry,I add a coat of color varnish to use on windowframes at home. Then with a fine brush strokes adding the woodgrain... Link to comment Share on other sites More sharing options...
