Max N Posted September 26, 2010 Author Share Posted September 26, 2010 While I'm at it, here are a couple of other placards made the same way Prop spinner Engine bearer with werknummer etc Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 I added the stud and nut to the engine mounting frame. This is the kit part I cut some guitar string for the studs, and some styrene hex for the nuts. Drilled a hole through the nuts (ouch) Painted the nuts and glued them on Close up Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 On the front of the engine, I added the wiring harness and spark plug wiring I replaced the kit intake and exhaust pipes. Here is the first stage, inlet pipes from brass rod bent to shape. Apologies for the poor photo but it gives the idea Later I painted the pipes black and they are practically un-noticeable now, I should have used a dark grey instead :-) Link to comment Share on other sites More sharing options...
nmayhew Posted September 26, 2010 Share Posted September 26, 2010 hey Max  slow progress is still progress!  some very cool work with your detailing and those placards look tip-top!  not sure about the blurry engine pic though - i have same problems sometimes, but i just keep deleting and re-taking the pic until i get it right / worth posting  your work is obviously very good!  thanks for the update - what scheme will you be doing btw?  Nick Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 26, 2010 Share Posted September 26, 2010 OMG, that engine detail is insane! Fantastic work Max. Â Kev Link to comment Share on other sites More sharing options...
dodgem37 Posted September 26, 2010 Share Posted September 26, 2010 Dang man, the engine looks so real it's actually running, blurring the picture! Who makes the 'kit' from which you made your dry transfers? Good show. Â Thank you. Sincerely, Mark Link to comment Share on other sites More sharing options...
big matt Posted September 26, 2010 Share Posted September 26, 2010 Cool work! I really like the nut and stud treatment. Those transfers are awesome too. Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 hey Max slow progress is still progress!  some very cool work with your detailing and those placards look tip-top!  not sure about the blurry engine pic though - i have same problems sometimes, but i just keep deleting and re-taking the pic until i get it right / worth posting  your work is obviously very good!  thanks for the update - what scheme will you be doing btw?  Nick  Hey Nick, thanks for the comments :-) Yep, the photo is the only one I seem to have from that stage of the engine work. The markings are Buhlingen's black <<+- if that makes sense Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 OMG, that engine detail is insane! Fantastic work Max. Kev  Cheers Kev :-)  Dang man, the engine looks so real it's actually running, blurring the picture!Who makes the 'kit' from which you made your dry transfers? Good show.  Thank you. Sincerely, Mark  Mark, its called Grafix Rubonz and I picked it up at a Hobbycraft store in Reading. The film is quite thick and not really useful for stencils or anything but works OK onto aluminium for placards. Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 Cool work! I really like the nut and stud treatment. Those transfers are awesome too. Thanks Matt :-) Â I am just uploading some more photos then I will post an update on the engine Link to comment Share on other sites More sharing options...
bdthoresen Posted September 26, 2010 Share Posted September 26, 2010 Nice work Max- Looking good so far. I like the addition of the placards- makes a heck of a lot of difference. Â Please keep it up- the 190 is one of my favorites of all time. Â Take care- Â THOR Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 This shot shows the air inlet for the supercharger. I removed the bulge on the kit part, and replaced it with an oval strip of sheet brass which was painted black. Then I inserted a brass mesh into the middle. Also in this shot you can see the first steps at trying to make the exhausts. The kit exhausts are over on the right. They are combined with the inlet pipes and are very unconvincing. I ended up using a combination of brass rod and brass tube. Here you can see two pipes have been made and I am test fitting them. Also two of the flared end pieces ready for the next two pipes. Also in this shot the fuel lines have been added - they should have been painted yellow but I chickened out! Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 Here four pipes have been made and are primed Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 Here is the engine with those four pipes fitted Link to comment Share on other sites More sharing options...
Max N Posted September 26, 2010 Author Share Posted September 26, 2010 Now two pipes on the left side: Link to comment Share on other sites More sharing options...
