F-86F Skyblazers 1/32 Italeri (Kinetic)
F-86 Italeri Kinetic
  • Please log in to reply
10 replies to this topic
#1 plane_mc
plane_mc
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 171 posts
  • Gender:Male
Posted 01 June 2015 - 05:10 PM
Here is my current project, the F-86F-30 from Italeri.
I live about 45 minutes away from where the aircraft on the box art is kept.  I have been watching it fly and sit in the Valiant Air Command Museum for quite a few years.
2015-03-14%20Tico%20-%20F-86F%20124r_zps
2015-03-14%20Tico%20-%20F-86F%20141r_zps
After the annual airshow this spring, I decided I needed to build a version of it.  This won’t be a completely accurate version of this F-86, but it will be representative of it.  I haven’t decided if I am going to make the markings as the plane is now, or when it actually flew with the Skyblazers.
I picked the kit up a couple of months ago and have slowly been working on it.  The only aftermarket that I am adding is a set of Harold’s resin wheels and HGW seatbelts.  I know the kit has some inaccuracies, but I am going to live with them and hopefully get a kit built!
I didn’t get any pictures until just recently, so some of my work is undocumented.
I started by closing in the back of the gun ports and re-drilling them, trying to make them a little more accurate.  I am not going to have the gun bays open and the gun ports will have the plugs in them.
Next I worked on getting rid of the seam on the intake and exhaust.  I also thinned down the back of the exhaust to make it look more scale.  I don’t want to use the intake and exhaust covers unless it really doesn’t look right after I get them painted.
For the cockpit, I used some sheet styrene and styrene rod to add some details.  I didn’t go crazy, just a few that I noticed in pictures.
I did the same thing with the seat, just added a few details with sheet and rod.
to be continued. . .
  • harvey, MARU5137 and Whitey like this
Current WIP: Do 335 B-2 HKM
On the backburner:  F-86F Skyblazers
On the backburner:  B-17G HKM
#2 plane_mc
plane_mc
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 171 posts
  • Gender:Male
Posted 01 June 2015 - 05:12 PM
continued. . .
I also drilled out the various vents on the rear fuselage and opened up the 2 intakes on the bottom of the rear fuselage.  I accidentally drill the vents wrong, so I had to fill them and start over.
That’s where I stand for now.  The progress is going to be slow, but I will try to update as I go.
Thanks for looking.
Mark
#3 shark64
shark64
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,760 posts
  • Gender:Male
Posted 01 June 2015 - 05:21 PM
Clean build.
So much history with that plane.
  • plane_mc likes this
#4 harvey
harvey
    Senior Member
  • LSP_Members
  • 19,244 posts
  • Gender:Male
Posted 01 June 2015 - 08:04 PM
NICE ! I like it.....Harv :popcorn:
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#5 plane_mc
plane_mc
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 171 posts
  • Gender:Male
Posted 02 June 2015 - 04:06 PM
Thanks shark64 and harvey.
#6 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 8,267 posts
  • Gender:Male
Posted 02 June 2015 - 06:35 PM
Good stuff, Mark. Looking forward to following along.
Sincerely,
Mark
#7 MARU5137
MARU5137
    Senior Member
  • LSP_Members
  • 20,048 posts
  • Gender:Not Telling
Posted 02 June 2015 - 10:12 PM
WICKED!!!
What a gorgeous looking aircraft ...
Glad to see it being built here..
Lovely start
:clap2:
Res Non Verba .
La calma è la virtù dei forti !
Potius Mori quam foedari.
#8 plane_mc
plane_mc
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 171 posts
  • Gender:Male
Posted 03 June 2015 - 04:11 PM
Thanks dodgem and maru5137
Edited by plane_mc, 03 June 2015 - 04:11 PM.
#9 plane_mc
plane_mc
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 171 posts
  • Gender:Male
Posted 15 June 2015 - 04:16 PM
Here’s a small update.  I have been working on this as I have time, just not making progress as quickly as I hoped to.
I got the fuselage halves glued together and have started working on the seams.  The engine is also together and what will be seen has been painted.  I will be gluing the front and rear fuselage halves together so the engine will not really be visible except through the intake and exhaust.
I also got the wing top and bottom pieces and control surfaces glued together.
I decided to add sway braces to the pylons, I still need to add the bolts.  The drop tanks are also glued together and I am working on cleaning up the seams.
That’s all for now, hopefully in a couple of weeks the updates will be coming closer together.
Thanks for looking.
Mark
  • harvey likes this
#10 Azgaron
Azgaron
    Senior Member
  • LSP_Members
  • 3,308 posts
  • Gender:Male
Posted 15 June 2015 - 04:57 PM
Looking good so far! Nice choice of markings!
Håkan
#11 harvey
harvey
    Senior Member
  • LSP_Members
  • 19,244 posts
  • Gender:Male
Posted 15 June 2015 - 10:14 PM
SMALL update ? Looks good so far.....Harv  :popcorn:
Also tagged with one or more of these keywords: F-86, Italeri, Kinetic
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
