Joel_W Posted March 28, 2017 Share Posted March 28, 2017 Danny, Very nice work with the PE. Interesting point about the gear door seals. This is the 1st I've heard of that. Joel mpk 1 Link to comment Share on other sites More sharing options...
mark31 Posted March 29, 2017 Share Posted March 29, 2017 Great job and thanks for the info on the tool going to order one Keep going Mark mpk 1 Link to comment Share on other sites More sharing options...
Cees Broere Posted March 29, 2017 Share Posted March 29, 2017 Danny, Make sure you check the fit of the enginecowling. The fitting of the engine should be sawn off and fitted one mm lower. There should be a tweak list about here. mpk 1 Link to comment Share on other sites More sharing options...
Gerhard Posted March 29, 2017 Share Posted March 29, 2017 I got it from Ushi himself. You can buy it at his webstore. https://www.uschivdr.com/shopping-categories/shop-tools-hardware/ Greetz Danny Sold out at the moment though. mpk 1 Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted March 29, 2017 Share Posted March 29, 2017 I`m late, but those door pieces shouldn`t be bent, they are seal to wheelbays made of rubber. Indeed they shouldn't.....thank's for pointing that out At the moment, my mistake is set right after i removed the bended pe part's from the wheel doors and flatten them back to the original setting. Danny, Very nice work with the PE. Interesting point about the gear door seals. This is the 1st I've heard of that. Joel Thank's Joel, interesting indeed, i didn't know that either. Great job and thanks for the info on the tool going to order one Keep going Mark Thank's Mark, with pleasure mate. Danny,Make sure you check the fit of the enginecowling. The fitting of the engine should be sawn off and fitted one mm lower. There should be a tweak list about here. Yes indeed Cees, i knew about that. But thank's mate for pointing it out, much appreciated Sold out at the moment though. I know it's a popular item, it will soon be back in stock i suppose. Greetz Danny Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted March 29, 2017 Share Posted March 29, 2017 (edited) . Edited November 17, 2019 by DannyVM Link to comment Share on other sites More sharing options...
Fenous Posted March 30, 2017 Share Posted March 30, 2017 Nice to see it was not FUBAR with the gear doors:-) Had the same problems with wheelsas you, I glued plastic strips inside the tires to preserve discs separate for painting, but your solution is also good, Personaly I also like the Deluxe materials putty very much. mpk 1 Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted March 30, 2017 Share Posted March 30, 2017 Nice to see it was not FUBAR with the gear doors:-) Had the same problems with wheelsas you, I glued plastic strips inside the tires to preserve discs separate for painting, but your solution is also good, Personaly I also like the Deluxe materials putty very much. Many thank's for the warning regarding the wheel doors. Regarding the wheels, different technique, same result, that's the magic of modeling. Greetz Danny Link to comment Share on other sites More sharing options...
Totalize Posted March 30, 2017 Share Posted March 30, 2017 Great build thus far. I was checking out that Deluxe modeling stuff but i don't think its available in North America. mpk 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 31, 2017 Share Posted March 31, 2017 I was checking out that Deluxe modeling stuff but i don't think its available in North America. If you're in Canada, Great Hobbies carries the full line of their products and I think they'll ship it too. Carl mpk 1 Link to comment Share on other sites More sharing options...
nichenson Posted March 31, 2017 Share Posted March 31, 2017 Great build thus far. I was checking out that Deluxe modeling stuff but i don't think its available in North America. Hobbyworld USA carries it. http://www.hobbyworld-usa.com/Store/modeling-tools/593-deluxe-perfect-plastic-putty.html mpk 1 Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted March 31, 2017 Share Posted March 31, 2017 (edited) Quote I was checking out that Deluxe modeling stuff but i don't think its available in North America. Edited November 17, 2019 by DannyVM Link to comment Share on other sites More sharing options...
mpk Posted March 31, 2017 Share Posted March 31, 2017 Awesome cockpit..I have place where you can put it...I'll PM you my address! Cracking build so far - pulling up a big comfy chair. Torben I wonder how many more Dottie Mae kits will be purchased after seeing this lovely build come together? Well done Danny! Troy Hmmmm, let me think..... Endorsement! Danny, I'll PM you the name of a good agent. Trustworthy.... Really... "Where's my money?" Typical. Anyway.... You make it as if you're walking on air. There's even a soundtrack!!!! Link to comment Share on other sites More sharing options...
Jasta 14 addict Posted April 2, 2017 Share Posted April 2, 2017 (edited) ................... Edited November 17, 2019 by DannyVM Link to comment Share on other sites More sharing options...
Guest Peterpools Posted April 2, 2017 Share Posted April 2, 2017 Danny Some mighty nice progress for sure. Very nice fix on the Brassin wheels but for what they cost, the fit should have been a lot better and no filler required. Drop tanks look very good both the the PE filler cap and the fix on the sway braces. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
