P-40F conversion build
  • Please log in to reply
101 replies to this topic
#46 Joel_W
Joel_W
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,549 posts
  • Gender:Male
Posted 18 March 2017 - 07:34 PM
The nose on the F is completely different from the E. That is why a whole new nose has to be used. Just cutting off the E intake would not even come close to making it a F (or L).
John,
  What I meant to say is that with the  nose clip, you'll have converted the E to an F. Sorry for my phrasing.
Joel
  • mpk likes this
Just Completed: Trumpeter 1/32 Scale A-4E Scooter
On my Bench: Kitty Hawk 1/32 Scale AV-10A Bronco
#47 mpk
mpk
    Senior Member
  • LSP_Members
  • 2,921 posts
  • Gender:Male
Posted 18 March 2017 - 09:16 PM
Great work thus far, John.
Here's a documentary you may not have seen but might give you some extra inspiration and ideas. I hope you enjoy it. :)
This is Pt 1. I think there are 3 parts. (Not watched it in a while)
  • JohnB and mmaben like this
My hat has a propellor.
10% faster. ;)
#48 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 20 March 2017 - 02:31 PM
Interesting.
Be careful of the toes that you step on today for they may be connected to the ass you have to kiss tomorrow.
#49 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 20 March 2017 - 02:49 PM
Mo betta. I'm glad I had another "E" kit to use for this. I carefully measured where to cut and made some adjustments plus plenty of trimming and test fitting (still needs some adjusting but it's a lot better than my previous try). Onward and upward!
  • johncrow, Martinnfb, Peterpools and 2 others like this
#50 Joel_W
Joel_W
    Senior Member
  • LSP_Members
  • 2,549 posts
  • Gender:Male
Posted 20 March 2017 - 06:46 PM
John,
  The overall fit does indeed look much better.  I still see that step on the starboard side. How about spreading just the lower corners with a piece of sprue, should just about remove it.
Joel
#51 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 20 March 2017 - 07:49 PM
John,
Joel
As you can see it's just taped together. There is still a bit of trimming and test fitting to do. After it's all cemented in place that "step" will be gone.
#52 Joel_W
Joel_W
    Senior Member
  • LSP_Members
  • 2,549 posts
  • Gender:Male
Posted 20 March 2017 - 07:51 PM
John,
    That's certainly the best solution of all. Looking forward to your next update with that work completed.
Joel
  • Lee White likes this
#53 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,417 posts
  • Gender:Male
Posted 20 March 2017 - 11:29 PM
Hi John
Nice work on fitting the new nose. A bit a filler and you're home free. I remember what my Meteor looked like after I cut off the forward fuselage and tail area for the Fisher conversion after tripple checking. Comparing mine to yours yours is a precision surgical cut.
Keep 'em coming
Peter
Trumpeter SBD-1
#54 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 21 March 2017 - 01:24 AM
Hi John
Keep 'em coming
Peter
Thanks Peter but I'm still having big problems. The upper contour of the resin nose does not conform to the contour of the kit. It's going to take a lot of filing, sanding, cutting, etc. BUMMER!!! I don't at all remember having this bad a fit problem when I did the "L" using the same resin parts. It's turning into a large PITA.
  • Peterpools likes this
#55 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,417 posts
  • Gender:Male
Posted 21 March 2017 - 01:29 AM
Hi John
I feel your pain.  After the Hurricane, it looked as if the P-40 was going to be a nice, easy and relaxing build. Sure doesn't seem to working out that way.
Peter
Trumpeter SBD-1
#56 ClumsyDude
ClumsyDude
    Senior Member
  • LSP_Members
  • 3,056 posts
  • Gender:Male
Posted 21 March 2017 - 01:30 AM
Hi John, the fitment of this looks really good. I don't know if it's the angle of the photo, the nose looks as if it's angled to port? Might just be the camera.
Jim
#57 Alburymodeler
Alburymodeler
    Senior Member
  • LSP_Members
  • 1,163 posts
  • Gender:Male
Posted 21 March 2017 - 07:51 AM
It looks like the exhausts need a bit of rejigging as well as there appears to be a few degree upward slope.
#58 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 21 March 2017 - 04:35 PM
Unfort
Hi John
Peter
Unfortunately true. I'm considering just putting it aside for a bit and starting something else. I can always come back to it later on.
#59 JohnB
JohnB
    Senior Member
  • LSP_Members
  • 6,785 posts
  • Gender:Male
Posted 21 March 2017 - 04:36 PM
No way that can be corrected without drastic surgery.
  • Alburymodeler likes this
#60 Joel_W
Joel_W
    Senior Member
  • LSP_Members
  • 2,549 posts
  • Gender:Male
Posted 21 March 2017 - 04:41 PM
Unfort
John,
  Sorry to see this, but after what you went through on the Fly build, this was supposed to be a basically OOB fun & relaxing build. I'm thinking that you're right in just putting it aside for a build or two, and work on something else that holds no surprises that you don't know about.
Joel
  • JohnB likes this
